Valve Stem Tips a little longer on exhaust valves
Old Feb 27, 2006 | 04:38 PM
"White Knight"'s Avatar
I was doing my LT4 Spring/rocker install the other day and I noticed after installing one side of springs that the tip sticking up above the keepers is a little bit higher on the exhaust valves. At first I thought I had a problem that the keepers were not quite fully seated, but it was just exhaust valves and was consistant. I didn't measure, but I think i will measure the diff. It had me a little worried. Why would this be? Anyone else ever notice this? Or do I have something wrong.
I forgot how much a PITA these SLP 1 3/4" headers are for changing plugs.
Old Feb 27, 2006 | 07:51 PM
MachinistOne's Avatar
Re: Valve Stem Tips a little longer on exhaust valves
Sometimes the flash-welded tips are taller, as long as the spring installeds are the same I would not worry about the tip length, it is an adjustable valvetrain.
Old Feb 27, 2006 | 10:22 PM
stroked383z28's Avatar
Mine were the same way. I'm curious about this as well.
Old Feb 28, 2006 | 12:53 AM
1racerdude's Avatar
If there is less than 1" difference it won't hurt a thing
Like Bret said "LASH UM"
Old Feb 28, 2006 | 07:40 AM
Javier97Z28's Avatar
Moderator
Yep, it's normal, seen it on multiple LT1's now
Old Feb 28, 2006 | 01:21 PM
Hey thanks
I just wondered if for some reason it was something with the keepers. The last thing I need is to drop a valve. Looks to be okay though.
Thanks for the replies seems to be normal by what everyone has mentioned.
Old Feb 28, 2006 | 01:32 PM
1racerdude's Avatar
Originally Posted by White Knight
Hey thanks
Thought====
It is a good practice to smack each valve stem with a 1lb hammer to seat the keepers.
Old Feb 28, 2006 | 01:57 PM
SStrokerAce's Avatar
It could be the height of the valve job or the valve length. Either way it's not too big of a deal.
Bret
Old Feb 28, 2006 | 02:08 PM
Thought====
Ah, I was thinking about doing that, I just didn't know if it was a good idea. I did use the wood end of a hammer and pushed down on it with all my weight on the first one that stuck up higher to check if they were fully seated. No problems with doing this? Just tap it enough to compress the spring a little?
Thanks for the tip. I think I might go back and do that--can never be too careful.
Old Feb 28, 2006 | 02:09 PM
1racerdude's Avatar
True
Ever since I had a keeper come loose after getting heads back from the shop,and ruining an engine I always smack the valves with a hammer to seat the keepers. When doing this on another occasion I had a keeper jump out and land on the bench( spring stayed on-Wheeew) That practice saved that engine.
I thought all shops did this but that is NOT true.
Just smack it medium hard. Just smack it-- sounds like a song there somewhere--maybe not.
Old Feb 28, 2006 | 02:12 PM
The installed height scared me the first time I checked it, until I realized the keepers have a "step" on them and don't fully seat on the barrel type micrometer. I read 1.860 installed height
Old Mar 2, 2006 | 06:05 PM
1racerdude's Avatar
Originally Posted by A/G
According to the original post, the relationship of the valve stem to keeper was not the same. This tells me it has nothing to do with the valve job. It wouldn 't necessarily mean a different length valve. Also, it could be a big deal depending on the height diff as this would alter the RA geometry if the same push rod length is used for both valves.
The rocker geometry would not be altered by this little bit to make a defference.
Old Mar 2, 2006 | 06:32 PM
1racerdude's Avatar
Note is did say IF. You and I do not know for a fact the actual amount do we?
Even.0625 in height won't make an significant difference.
Yea there are a lot of IF's.
Old Mar 2, 2006 | 07:42 PM
I always do, I like the song it makes BTW
Old Mar 2, 2006 | 08:11 PM
Moderator
I've seen this on *multiple* stock LT1's...
