Valve Stem Tips a little longer on exhaust valves
I was doing my LT4 Spring/rocker install the other day and I noticed after installing one side of springs that the tip sticking up above the keepers is a little bit higher on the exhaust valves. At first I thought I had a problem that the keepers were not quite fully seated, but it was just exhaust valves and was consistant. I didn't measure, but I think i will measure the diff. It had me a little worried. Why would this be? Anyone else ever notice this? Or do I have something wrong.
I forgot how much a PITA these SLP 1 3/4" headers are for changing plugs.
Re: Valve Stem Tips a little longer on exhaust valves
Sometimes the flash-welded tips are taller, as long as the spring installeds are the same I would not worry about the tip length, it is an adjustable valvetrain.
Originally Posted by stroked383z28
Mine were the same way. I'm curious about this as well.
Like Bret said "LASH UM"
Hey thanks
I just wondered if for some reason it was something with the keepers. The last thing I need is to drop a valve. Looks to be okay though.
Thanks for the replies seems to be normal by what everyone has mentioned.
Originally Posted by White Knight
Hey thanks
It is a good practice to smack each valve stem with a 1lb hammer to seat the keepers.
Thought====
Thanks for the tip. I think I might go back and do that--can never be too careful.
True
Ever since I had a keeper come loose after getting heads back from the shop,and ruining an engine I always smack the valves with a hammer to seat the keepers. When doing this on another occasion I had a keeper jump out and land on the bench( spring stayed on-Wheeew) That practice saved that engine.
I thought all shops did this but that is NOT true.
Just smack it medium hard. Just smack it-- sounds like a song there somewhere--maybe not.
The installed height scared me the first time I checked it, until I realized the keepers have a "step" on them and don't fully seat on the barrel type micrometer. I read 1.860 installed height
Originally Posted by A/G
According to the original post, the relationship of the valve stem to keeper was not the same. This tells me it has nothing to do with the valve job. It wouldn 't necessarily mean a different length valve. Also, it could be a big deal depending on the height diff as this would alter the RA geometry if the same push rod length is used for both valves.
The rocker geometry would not be altered by this little bit to make a defference.
Note is did say IF. You and I do not know for a fact the actual amount do we?
Even.0625 in height won't make an significant difference.
Yea there are a lot of IF's.
