valve springs and lift
Old Jul 26, 2005 | 07:21 PM
LT1powered94's Avatar
Ok i'm putting in a custom ground CC that I bought for cheap. I'm keeping the stock rockers for maybe as long as a year. But I will get some rollers, maybe 1.5 maybe 1.6. I'd like to know what springs would work for all three rockers. And would 1.5 or 1.6 be better on stock heads. Basically is too much lift a bad thing?
cam spec 214/224 .531 .502
Old Jul 26, 2005 | 09:34 PM
96trans am's Avatar
Re: valve springs and lift
Thats a small cam, you may be okay with the stock springs. Im sure someone will know what the stock springs are good up to. But if you are going to do springs you probably should throw on some 918 beehives. Its a real popular spring that is good up to .600 lift. With 1.6 RR's your lift is still very low. 1.6 RR's will be better for ya.
Old Jul 26, 2005 | 09:54 PM
ZMAN Z28's Avatar
Nope stock springs won't work. The hot cam only goes to .525 with 1.6 rr's, and that needs new springs. I wouldn't even use the LT-4 springs with that cam. I think crane makes some good to .540 lift. The lift you specified, is that with 1.6 rr's already fugured in. If not, and you get 1.6's, that will make the lift bigger.
ZMAN
Old Jul 27, 2005 | 12:41 AM
Thats the lift for stock rockers. I really dont' know how to figure the lift for 1.6 rockers.
Old Jul 27, 2005 | 12:47 AM
Dave89IROC's Avatar
.566/.535 w/1.6 rockers
to get lift with a different ratio, divide by stock ratio(1.5), then multiply by new ratio(1.6)
Old Jul 27, 2005 | 01:40 AM
MachinistOne's Avatar
Are you sure they are putting more lift on the intake than exhaust? Re-check that....
Old Jul 27, 2005 | 03:08 AM
ZMAN Z28's Avatar
Take the lift number and divide by 1.5. Take that number and multiply by 1.6.
Z
Old Jul 27, 2005 | 03:46 AM
sssalah's Avatar
The stock springs wont work for sure with that lift as mentioned. One thing that shoud not be overlooked is if the stock rockers are able to coupe with this lift, stock rocker is lift limited by the length of its slot. If that's the case then the least damage can be bent pushrods.
Old Jul 27, 2005 | 05:41 PM
Yes the intake has the bigger lift. I'm not sure why (nitrous maybe?). I thought it was better than nothing and i got it dirt cheap. So how do I find out if my stock rockers will work?
Old Jul 27, 2005 | 11:14 PM
1racerdude's Avatar
Call Comp and give them the grind number.They will tell ya what springs will go with your cam.
The beehive springs might be worth looking into,ask Comp Cams.
To much lift isn't a bad thing unless valves start hitting pistons.
Old Jul 28, 2005 | 01:13 AM
Thats what I was looking for. Really obvious if you think about it. Man I feel dumb missing things like that.
Old Jul 28, 2005 | 01:21 PM
1racerdude's Avatar
Glad to help.
Old Jul 28, 2005 | 01:28 PM
SStrokerAce's Avatar
You need a healthy valve spring and good rockers to run that cam.
214 @ .050 with .353 lobe lift (.530 w/ 1.5's, .560 w/ 1.6's)
That's ethier a XFI lobe or a 3190, both of which need really good springs, good pushrods, good rockers and 7/16 studs.... it's far from a bolt in unless you want to break a lot of parts.
Bret
Old Jul 28, 2005 | 05:53 PM
well .... can you make some recomendations on springs and pushrods? Or are you agreeing with the call Comp comment? This is going in a daily driver and I consider myself pretty easy on my car.
Old Jul 28, 2005 | 10:11 PM
Yeah, either a set of 977's with Ti retainers or a set of Beehives with steel retainers would work. I always run Comp Hi Tech 5/16 pushrods or better, and I would also do a set of Comp Pro Mags with 7/16 studs if I was running that intake lobe.
Bret
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
