valve spring questions
Old Jul 22, 2005 | 02:00 PM
theonly95SS's Avatar
ok guys i have a GTP cam with a lift of .595, on a 1.5RR which i will be running for now, upgrading to a 1.6 later pushing the lift over .600 i need upgrade my valve springs so what should i go with, and what springs need new seats locks retainers etc...
i was recomended the k-motion k-800's but after buying new seats, locks, and retainers im close to $300 i think that seems bit high, but i have never messed with springs before so i dont know
thanks guys
Old Jul 22, 2005 | 02:30 PM
BUBBA's Avatar
Re: valve spring questions
With that high of lift you will most lilkely be looking at triple spring with seats larger than 1.46 which means machining the seats (which I assume you already know). So you are going to have to consider how much it will cost you for machining alone on top of head removal and replacement, purchase of springs, retainers, keepers, etc.
Your cam card should tell you the recommended pressures and install heights.
You should have the machinist install the springs while they have the heads to ensure a good install and fit.
I don't know about K-Motions. Frankly, I'd go with Crane, Comp Cam, Crower or somebody like that. JMHO
Old Jul 22, 2005 | 03:08 PM
JustNO's Avatar
Look at comp cam 977 springs (155lbs pressure on seat)
well judging by what i have heard from other people that seems a bit over the top, but then again better safe then sorry, also does anyone know the stok valve stem size?
thanks guys
Old Jul 22, 2005 | 03:33 PM
ZMAN Z28's Avatar
With 1.6 rockers, that will give you .635 lift.
ZMAN
Old Jul 22, 2005 | 04:21 PM
JustNO's Avatar
oh its a solid roller or what?
Old Jul 22, 2005 | 04:22 PM
hydraulic (sp?)
oh damn sorry i just noticed i put .595, i ment .525 on 1.5 sorry about that
Old Jul 22, 2005 | 04:49 PM
mr_will's Avatar
comp 918's should handle that cam
no machine work required
Old Jul 22, 2005 | 05:05 PM
1racerdude's Avatar
thanks guys
Look into the Comp Beehive that would have 150#seat and 350# open on the nose. They will loose 15-25# after a few heat cycles.
A real good set with all the jewelry cost $500.00 so $300.00 ain't bad.
Old Jul 22, 2005 | 05:43 PM
ZMAN Z28's Avatar
That will give you .586 or .587 lift depending upon how you round off.
ZMAN
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
