valve spring question
Old Mar 13, 2007 | 07:48 PM
slp97camaro's Avatar
im putting the gm847 cam in my car w/ 1.6rr's. so the lift would be .575/.596 if im correct...but heres my question..would isky racing valve springs that say they're good up to .600 lift be alright? cuz i know the exhaust lift is getting pretty close to what it says the springs are good for.
just wanted to make sure it will be okay so i dont put it all together and find out i have valve float, thanks!
Old Mar 13, 2007 | 08:15 PM
SS RRR's Avatar
What's the spring rate?
What's the install height?
Where's coil bind?
Old Mar 13, 2007 | 08:44 PM
i dont have any of those numbers off hand...i just know the guy porting my heads said they come assembled w/ .600 lift isky springs
so can you even tell if it would be okay w/o those numbers? or is anyone else have isky springs on there car?
Old Mar 13, 2007 | 10:35 PM
.596 lift and .600 springs would be cutting it too close for my taste.
Old Mar 13, 2007 | 11:12 PM
seawolf06's Avatar
Yep, even if you installed them all exactly correctly it would be close. We don't know if they'll work given only the "rated lift" but it doesn't look like they will.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
