valve size in ported heads
Old Aug 14, 2005 | 08:30 PM
Fbody1's Avatar
Talking valve size in ported heads
i am having to replace the valves in my heads the heads have already been ported should i use 2.02/1.60 or 2.00/1.56 i have a hotcam now but may put 1.7 rr on later so what size valves would be best for street driving?
Old Aug 14, 2005 | 08:39 PM
FastZinTennessee's Avatar
Re: valve size in ported heads
The best combination on my ported heads I found through testing on a flowbench was 2.00" Manley RaceFlo intake valves, and stock exhaust valves. The comparison was Manley RaceFlo 2.00" intake and 1.56" exhaust vs. stock valves. The 2" Manley intake valve outflowed the stock intake valve, and the stock exhaust valve outflowed the Manley 1.56" exhaust valve.
I think a larger exhaust valve gets too much shroud in the combustion chamber, and since the stock exhaust valve is smaller it doesn't suffer from this as much. And yes, I did open up the chambers around the seat and also worked on unshrouding it, but the stock exhaust valve still flowed better.
Stock exhaust valve flowed a peak of 3.2 cfm more than the Manley counterpart at .400" lift.
Manley intake valve flowed a peak of 6.5 cfm more than the stock counterpart at .300" lift.
Old Aug 15, 2005 | 12:49 AM
blackztpi's Avatar
i can't provide any flow numbers or tech info, but i can say that 2.02/1.60's made a badass out of a hotcam. guy around here dynoed around 380rwhp and much over 400rwtq. this particular car sounded like a 306 grind rather than a hotcam. very wild sounding hotcam. one hotcam car i wouldn't mind having
Old Aug 15, 2005 | 12:53 AM
amean94ta's Avatar
i went with the 2.02/1.60 manley race flows and i doubt the 2.00/1.56's would get me close to where i am now. you will have to have them install new seats though and if i did it again i would go 2.05/1.65
Old Aug 16, 2005 | 07:01 PM
Fbody1's Avatar
well I think I will get the 2.02 1.60, manley race flow , they look like a good valve. thanks for the input
Old Aug 17, 2005 | 04:11 PM
Sometimes I wonder why I even bother replying
Old Aug 17, 2005 | 06:03 PM
slverbullet's Avatar
dude, what kind of bottom end setup did this guy have to put out over 400rwtq?
seems pretty irrational with just a hotcam (or with a stock bottom end setup in general). but thats just my opinion.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
