Valve seats
Old Jan 24, 2007 | 07:04 PM
30696bird's Avatar
Valve seats
I talked to my head porter and he said if I use the ferra 2.02 / 1.60 valves that I'd have to have new valve seats. First off, is this true.......second, what is a reasonable price for them. he quoted me $100 for the seats.....$100 to install. Does this reasonable.......or is he trying to make more money off of me?
Old Jan 24, 2007 | 07:17 PM
MachinistOne's Avatar
Yes - you need seats to go that big.
I would charge about $5-7 per seat and $150 to install. - Edited, forgot you need all 16.
Old Jan 24, 2007 | 07:30 PM
30696bird's Avatar
I guess I'll give him the go ahead then. He ports heads here local and has some cars in the 6.30's (1/8 mile, N2O). His heads flow in the 270-280's range. He did a set of heads, valves, and ported a intake for $1025 so I'm pretty happy. EVERYONE here local says good things about him..............we'll see.
Old Jan 25, 2007 | 09:15 AM
NightTrain66's Avatar
next option is to use the 2.00/1.56 valves that are designed for the LT1 heads and stock seats.
The $200 is about right for the larger seats installed. These are needed when going 2.02/1.60's.
Using the 2.00/1.56 valves will save you $200 (since no seats are neaded) and there is a very small difference in the power of a 2.00/1.56 versus a 2.02/1.60.
You might hit the porter up on this.
Old Jan 25, 2007 | 02:02 PM
30696bird's Avatar
THANK YOU! I was hoping you would chime in.
Fastbird93
Apr 9, 2016 07:01 PM
dylan1303
May 22, 2015 12:24 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Timberwolf
Jul 30, 2002 08:31 PM
