Which Valve Seals fit an LT1 w/o modification?
Old Dec 21, 2005 | 01:47 AM
HardcoreRM125's Avatar
Bret told me Viton seals would require some modifications for them to be a direct fit. So which valve seals go rite in, no modifications?
11/32", in which style?
I will be going with Comp Bee Hives PN 26918-16 Springs, and these Retainers ( I think ) Comp Steel Retainers, PN 795-16.
Old Dec 21, 2005 | 02:16 AM
MachinistOne's Avatar
Re: Which Valve Seals fit an LT1 w/o modification?
Factory seals are Viton. A fel-pro kit will have the correct seals. You might need to have the guides cut anyways depending on how much lift your cam has. If they do need to be cut, that will drop the diameter down from .557" to .530"
Old Dec 22, 2005 | 12:07 AM
Ok Thanks,
I will not be cutting them down for now as I have the stock cam still.
Im trying to build the motor one step at a time, getting all the little stuff done before I cam it/bore & stroke. That way when it comes time to actually make some power, the little stuff doesnt hold me back/screw me financially.
HectorM52
Jul 30, 2017 11:46 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
thenewkid
Nov 29, 2014 04:54 PM
