valve problem
Old Jun 3, 2007 | 09:29 PM
brucetrentcamaro212's Avatar
valve problem
going to try to adjust my valves with engine not running just didnt
know the difference between exhaust valve and intake valve. anyone tell me the difference between them thanks
Old Jun 3, 2007 | 10:17 PM
Front to back (or even back to front ) on both sides:
E-I-I-E-E-I-I-E
Old Jun 4, 2007 | 06:09 PM
ok I started to adjust my valves with engine off and i was pretty sure I was in TDC. so I adjusted the ones i was supposed to and then turned 360 and stared to do those and then felt the ones I done before and they are very loose is that normal. or did I not have it in TDC after all. is there a better way to get it in TDC then placing a pen in the number 1 spark plug hole and turning the hub intill it comes out. Because its kinda hard to do it this way...
Old Jun 4, 2007 | 06:40 PM
There is a "how to" on valve adjustment on my Tech Page.
You have to know which cylinder TDC you are at to get started.
Old Jun 5, 2007 | 05:45 PM
Ok I found out how to get my car at TDC #1 but I had the car in TDC#6 and started with those intake and exhaust valves first and then turned it and went on to the #1 and now after doing this the car wont start it makes a wierd nosie that i havent heard before. But it make no effort to start, Did I tighten them to much. I was turning the pushrod as i was tightening them and when i couldnt turn the pushrod anymore I then tighened it 3/4 more. Please help
Old Jun 6, 2007 | 08:32 AM
If you started adding preload after you could not turn the pushrod, they are too tight. Zero lash is explained on my website and is before you cannot turn the pushrod.
Old Jun 6, 2007 | 08:36 AM
thanks for the reply. I didnt know after reading your tech page if there should be anymore spining on 0 lash so I was pretty sure I got them to tight just wanted to double check with you guys before I took everything apart again.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jazsun
Dec 29, 2014 12:14 PM
