Valve Lash Adjustments
Old Apr 10, 2008 | 01:46 PM
  #16
The 1 turn has been the norm from GM on hydraulic lifters for like forever. The actual LT1 spec is 1 turn + or - 1/4 from zero lash.
Old Apr 10, 2008 | 04:52 PM
  #17
hairbear21's Avatar
Awesome, thanks a lot guys!
Old Apr 10, 2008 | 09:46 PM
  #18
truedualws6's Avatar
Originally Posted by stereomandan
I thought factory recommended a different value for preload, 1/2 turn.
Is there a link to this? I set my 7/16" studs to 3/8 turn based on some information that I looked up years ago based on GM preload specs, but can't find it now. It's rans great, and quiet.
Dan
Dan, as also stated by shoebox, and to quote my 1997 factory service manual "When all the free
play is gone, tighten the valve rocker arm nut 1 additional turn (360 degrees)". If you have a
service manual it's on page 6A-265.
Old Apr 11, 2008 | 06:24 AM
  #19
wrd1972's Avatar
Good dicussion.
Is there any truth that for higher performance motors using OEM lifters that 1/8 - 1/4 turn PZL is more desirable than the GM spec of 1 turn PZL?
Old Apr 11, 2008 | 04:02 PM
  #20
stereomandan's Avatar
Wierd. I know there was a very good reason that I used 3/8 turn with my 7/16" studs, at the time. I did with the engine not running, and it has been fantastic. Very quiet, no ticking, no performance issues that I can find...
I thought that I had calculated what the max capable preload is (basically when the lifter becomes solid) and shot for half way to that point. That way I would have equal travel for the roller in the lifter in both directions.
Maybe I calculated it wrong? What is the distance from zero preload to full solid on a stock GM roller lifter?
Dan
Old Apr 12, 2008 | 11:08 AM
  #21
wrd1972's Avatar
Originally Posted by wrd1972
Good dicussion.
Anyone want to speak to this
Old Apr 12, 2008 | 11:36 AM
  #22
The old adage is "looser is faster". Looser=less preload.
Old Apr 12, 2008 | 12:02 PM
  #23
I'm going to stick with 3/8 turn on stock lifters, with 7/16" studs. Even if I swap to a new cam. My valvetrain sounds great, and I don't get any false knock (I datalog my car a lot).
Dan
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
FredM
Apr 10, 2015 02:56 PM
