valve float
Old Mar 26, 2007 | 07:48 PM
pattracing212's Avatar
valve float
i think i am experiencing some valve float. i hav enever had it before in any previous car i owned. it basically falls onm its face and has almost a gargling noise in high rpm's. at what rpm would you normally see valve float on a stock cam and springs. i was also told it could be a broken spring. i am gonna try and check tomorrow. btu i would first just like some info on the valve float. is it bad for your engine
Old Mar 26, 2007 | 08:17 PM
anyone?
Old Mar 26, 2007 | 10:20 PM
Bow94z's Avatar
your sig says you have 1.6 rockers. From extensive research i've donw with my 1.6 rocker swap, using stock springs is a big mistake, at least use LT4 springs w/ 1.6 rockers and stock cam...
I'd say your stock springs cant take it anymore
Old Mar 27, 2007 | 03:50 AM
rskrause's Avatar
Moderator
Sounds like the valve springs are shot.
Rich
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
