Valve covers & 1.6 roller rockers
Old Aug 28, 2007 | 12:01 PM
pizzi-man's Avatar
I want to know if there are clearance problems with the 1.6 roller rockers and stock valve covers and if so what to do about it.
Old Aug 28, 2007 | 12:09 PM
Some need clearancing and some don't. It depends on the brand of rocker arms. What do you have?
Old Aug 28, 2007 | 12:52 PM
pizzi-man's Avatar
They are the crane roller rockers. I had to flatten the webbing in the valve covers that support the center bolts to get the valve cover past the rockers but have not adjusted the rockers yet. These are on afr 195 heads.
Old Aug 28, 2007 | 12:53 PM
raroz28's Avatar
If you're using comp nsa 1.6 rockers you will have to break each bracket off the cover.
I use some good steel cutters and scissored them off.
Ok, you have cranes, I posted b4 I saw. Just try to put the cover on, if it doesn't fit, cut the brackets off.
Old Aug 28, 2007 | 01:26 PM
pizzi-man's Avatar
Thanks razor but I don't like to cut if I don't have to. By flatening the bottom of the webbing I was able to slip them on. I was wondering about the poly locks hitting the top of the valve cover as some one told me I needed taller valve covers for the rockers. Better to ask a stupid question then to fix an expensive stupid mistake
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
