Valve cover problem
Old Mar 23, 2008 | 01:45 PM
Ironxcross's Avatar
Valve cover problem
I got some 1.6 rockers and poly locks the other day and installed them. Valve covers didn't fit, so I took the baffles out of them and now they fit. The problem now is that they're hollow, oil likes to find its way up the bolt and leak out on the top of the valve cover. Is there anyway to fix this or is there a cheap good valve cover to get that has enough clearance without me having to relocate traction control and all that?
Old Mar 23, 2008 | 02:25 PM
dangalla's Avatar
you may have "over modified" but its hard to tell from your post
you should have done this
http://www.golenengineservice.com/ht...html#valvecmod
Old Mar 23, 2008 | 02:27 PM
Ironxcross's Avatar
definately over modified
Old Mar 23, 2008 | 02:30 PM
dangalla's Avatar
try a local junkyard or something for another set to try again
or check the classified section here
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 29, 2014 04:54 PM
