valve cover leak
Old Mar 18, 2007 | 05:59 PM
Purplemaroz28's Avatar
valve cover leak
i have a set off prostamped valve covers and they spit oil out the oil fill hole, right now i have rubber gromets in it to cover it up, do i need a breather cap?
Old Mar 18, 2007 | 07:47 PM
SS RRR's Avatar
I guess it's possible the fill hole is out of round. Have you checked the cap to make sure it's not cracked? This only started after you put the valve covers on?
IMO I'm compltely against breathers for street cars with the stock PCV system in operable condition. Completely unecessary.
Old Mar 20, 2007 | 07:17 PM
it didnt happen before with stock valve covers, but the engine is completely changed, from then, when i pulled my motor i bent the stock valvecoveres. any other ideas, why are u against breather caps?
Old Mar 20, 2007 | 07:18 PM
LiENUS's Avatar
They're a vacuum leak into your system. They let unmetered air past the tb.
Old Mar 20, 2007 | 07:28 PM
SS RRR's Avatar
Because the stock PCV system is plenty enough to handle any pressure from inside the engine, I caution calling it "blowby" because some will deem that term automatically as being bad when even a healthy engine has blowby of some sort. Besides I think breathers look ugly on a street engine. Especially if one doesn't take care and constantly clean the dribble of oil vapors they create all over the valve cover.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
ModdedNerd
Jan 29, 2015 07:23 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
