Valve Cover Clearance with 1.6RRs
Old Jul 22, 2004 | 03:21 PM
JennyOnNos's Avatar
I just installed pro mags and the valve covers won't clear. Is there a place were I can get a set that will fit or can the stock ones be modified to do so? Thanks
Old Jul 22, 2004 | 03:24 PM
disco192's Avatar
Re: Valve Cover Clearance with 1.6RRs
the problem is there is a piece of metal that slides inbetween the rockers. You need to get some pliers and bend the valve covers straight (be careful not to mess up the bolt holes, keep the bolts in the holes in the valvecover). It is a little tricky, but you will see what i am talking about.
Old Jul 22, 2004 | 04:21 PM
jkayner's Avatar
or you can cut the brace that goes between the rockers. Look in my signature and click on the install page. go to the RR install page and you will see what I'm talking about...
EDIT:
ok sorry i just looked back on the page and we didn't post those pictures. lemme see if i can find it...
Old Jul 22, 2004 | 04:24 PM
simple's Avatar
you will see a tiny lip on that support piece, that lip needs to be bent flat to fit in between the rockers, you will only need to bend that lip on the side of the valve cover closest to the intake manifold, the other side doesnt sit between the rockers so it wont need bent
Old Jul 22, 2004 | 04:57 PM
JennyOnNos's Avatar
Thanks guys. Problem solved.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
thenewkid
Nov 29, 2014 04:54 PM
