Valve adjustment. How often?
Old May 15, 2011 | 09:26 PM
raroz28's Avatar
How often should I adjust my valve lash? My car is a tad down on power, specifically the "right now" throttle response. I have replaced the air filter, cleaned the MAF and TB, replaced fuel filter, and put my old plug wires back on (took off the Taylor OTVC set).
I have Comp NSA 1.6 Rockers. They have not been adjusted since the summer of 2006 and I was wondering if maybe those rockers need to be adjusted more often.
Old May 15, 2011 | 09:28 PM
OBE1 95Z28's Avatar
Re: Valve adjustment. How often?
Unlikely that the valves are the source of your power lose. Your lifters are hydraulic and therefore don't need periodic adjustment. Solid lifters require regular maintenance. Additionally your rocker arms should have locking retainers to keep them from coming loose over time. Are you hearing any clattering of your valve train?
Old May 15, 2011 | 09:36 PM
raroz28's Avatar
No clatter, just a little tick. I have noticed it for a while and a guy the other day said it sounded like my valves were out of adjustment.
I'm not sure if it's a slight exhaust leak or if it is top end noise, but this power loss is frustrating and I am running out of things to check out.
Old May 15, 2011 | 11:11 PM
OBE1 95Z28's Avatar
The PCM might be pulling timing due to you knock sensor; need to run some diagnostic software and read your knock counts.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
