Valve Adjusting
Old Nov 14, 2005 | 07:55 PM
ChrisUlrich's Avatar
Valve Adjusting
Can valve adjusting cause hard startup or stumbling? I have a brand new motor and the preload hasn't been reset since the initial install when the motor was being built.
Can this have ANYTHING to do with a hard stumble going from open to closed loop?
Old Nov 14, 2005 | 11:03 PM
Re: Valve Adjusting
Valves too tight will not let the engine create much vacuum. It will run especially rough at low RPMs and have no power.
Old Nov 15, 2005 | 09:33 PM
SStrokerAce's Avatar
Re: Valve Adjusting
Well if they are now loose then yeah the SOB might not run at all!
Bret
Old Nov 15, 2005 | 10:39 PM
MachinistOne's Avatar
Re: Valve Adjusting
Yeah - What shoebox said, but going from open to closed loop operation & valve lash would not be related issues....that's a programming problem. Tell us the build of the motor... stock? modified?
You shouldn't have to re-run the lash if it was done correctly the first time.
Old Nov 16, 2005 | 01:34 PM
Re: Valve Adjusting
I heard no matter what once the car is started and the breaking in has begun, you have to reset the lifter preloads?
Old Nov 16, 2005 | 02:20 PM
97bowtie's Avatar
Re: Valve Adjusting
That's not always true. If the valves are too tight, the intake and/or exhaust valves may not be closing all the way. This can cause the a/f mixture to leave the combustion chamber before they are ignited....causing false O2 readings. These readings will be ignored until the car goes into closed loop. This condition can cause the car to run like crap, and run even worse once the car goes into closed loop and the car starts adjusting for the off mixture.
Old Nov 16, 2005 | 08:14 PM
Re: Valve Adjusting
That would not be the cause of the problem he described though. At idle and cruise, yes, the computer is looking for 14.7 AFR through the O2 sensors, and at WOT it will resort to programming. A hard stumble would be programming issues. Unless I am reading you wrong, your description of closed vs open loop are reversed.
Old Nov 16, 2005 | 11:08 PM
1racerdude's Avatar
Re: Valve Adjusting
O2's can't sense raw fuel in the exhaust. They sense gases and not liquid.
Old Nov 17, 2005 | 09:49 AM
97bowtie's Avatar
Re: Valve Adjusting
Right, but they can sense a false lean or rich condition. If the fuel is leaving the combustion chamber before it's ignited, it will ignite in the exhaust manifold/header primaries. This ignition will leave behind gases, not proportional to the actual a/f ratio being injected into the combustion chamber.
Old Nov 17, 2005 | 12:16 PM
1racerdude's Avatar
Re: Valve Adjusting
Ya can tune it so rich it shows lean and so lean it shows rich.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
