vacuum leak? help please
Old Jun 6, 2006 | 11:15 AM
bldjello's Avatar
Hey, can anyone help me pin-point a problem please?
when my car gets hot (after i drive it for a while when its roughly 95 out) and i pull up to a red light or have to stop, my car tries to pull forward, so i either have to hold the brake really hard, or if i slip it into neutral it rev's up real high then lets off, then when i go to leave from the light (put it back in drive) and take off it feels like it bogs really hard.
what could that be?
also, my brake light is on, as well as my ABS INOP light any suggestions?
Old Jun 6, 2006 | 12:15 PM
Sweetred95ta's Avatar
Re: vacuum leak? help please
Did you check/listen for a hissing sound (leak) under the hood? Sounds like a vacuum leak. Just check everything. It doesn't take very long.
Old Jun 6, 2006 | 12:53 PM
bldjello's Avatar
i have but i cant notice anything loud enough to know its a vacuum leak so i wasnt sure, i heard it could also be due to the fact that i NEED a tune up which im getting this weekend , but i was just seeing if there was any other problem i should be aware of
Old Jun 6, 2006 | 02:39 PM
Doesn't sound like a tune-up type problem to me. Do you have a labtop? You could buy a cable and download Freescan or PCMComm (both for free) and check your MAP sensor readings. That will tell you if you have a vacuum leak or not (most likely). Cables are like $45 from Mastach.com. Maybe you should inspect all of your hoses and fittings. Start with the brake hose.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
rideordie
Sep 7, 2015 08:22 AM
