Vacuum Leak?
Old Sep 7, 2005 | 07:22 PM
matLT1's Avatar
Vacuum Leak?
I am wondering what kind of vacuum you guys get with a relatively stock engine. I am getting about 18 in Hg +/- .5 in Hg. The reason I ask is at times the engine will idle rough (generally once it is warmed up). Things I have replaced are the hose running from the evap solenoid to the TB, the o-rings, the intake gaskets and the throttle body gasket. The interior vents are working fine so I don't think there is an under dash leak. Thanks in advance.
Old Sep 7, 2005 | 09:29 PM
Re: Vacuum Leak?
18-20 is about normal for hot idle.
Old Sep 7, 2005 | 10:46 PM
1racerdude's Avatar
Re: Vacuum Leak?
Got tune up lately???
Old Sep 8, 2005 | 03:54 PM
matLT1's Avatar
Re: Vacuum Leak?
I did the plugs last year and replaced the wires roughly a month ago. I'm suspicious of the ignition though. Once or twice a week I will get a backfire from the tail pipe.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
rideordie
Sep 7, 2015 08:22 AM
