v6-lt1 conversion help please
Old Apr 3, 2003 | 07:53 PM
ponykiller z28's Avatar
ok my 97 camaro lt1 conversion is 95% complete but i can't get my fuel pump and starter to activate when i turn my key on. Is there some kind of ground wire that i might have overlooked or not hooked up? i looked and i couldn't find any but i could be overlooking it.
is there anything else it could be?
also, it is not absolutely necessary to have a v8 radiator as long as i have the dual fan setup?
pleeeease reply with any suggestions. THANKS
Old Apr 3, 2003 | 08:04 PM
94-3.4's Avatar
Can you give more details about your swap? I did the swap to mine and had no problems.
I would first check all your fuses both the ones on the side of the dash and in the engine bay.
Did you go from a 5 speed to auto or something like that?
Old Apr 3, 2003 | 08:23 PM
Mtrhds94Z's Avatar
What's the LT1 motor out of? [as in what water pump do you have on it?]
If it's an fbody LT1, where did you hook the radiator 'bypass hose' to['3rd hose' from WP to drivers side of radiator]
V6 radiator doesn't have that, does it?
[Corvette WP, for instance, doesn't have the 'bypass hose']
Old Apr 3, 2003 | 08:43 PM
the lt1 is out of a 95 trans am. i just put a v8 automatic transmission in there where the old auto tranny was. there is nowhere to put the bypass hose on the v6 radiator so i am gonna try to just close it off for now.
thanks for replies
Old Apr 3, 2003 | 08:49 PM
Mtrhds94Z's Avatar
OK if you want a permanent solution[ maybe after you see that it doesn't run hot with the V6 radiator?] try an LT1 vette pump.. [I don't think it has the 'bypass' fitting on it..]
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
