using water instead of coolant?
Old Dec 21, 2004 | 05:54 PM
luis nunez's Avatar
will I have any problem if I use water on my LT1
like about 85% water and 15% coolant?
Old Dec 21, 2004 | 06:24 PM
jkipp84's Avatar
Re: using water instead of coolant?
The coolant is actually an antifreeze, anti-corrosive, and anti-boil. Too little and you may run into some trouble in these areas.
Is 15% too little? Dunno.. sounds like it to me though.
Evil Eric's Avatar
well, first does the temperature drop below freezing there? that might cause you a problem. i read an article in HOT ROD that said that pure distilled water dissipated heat 20% more effictively than the best coolant on the market when used with a corrosion inhibiter (water wetter or purple ice)
Old Dec 21, 2004 | 06:28 PM
Fuels94TA's Avatar
ditto....
Old Dec 21, 2004 | 06:53 PM
Cwynn's Avatar
The water is under pressure, therefore it will not boil at 212deg F. the normal boiling point at sea level.
Old Dec 21, 2004 | 06:57 PM
luis nunez's Avatar
thanks.. here the temperature is almost all yaer from 70s-90s
I know that 15% is too little but I was broke, lacy, and a bit mad at my car an decided to put just watter and what was left from a coolant that i had
Old Dec 21, 2004 | 08:09 PM
Spinner's Avatar
Pure distilled water is fine. I've run it in the summer for several years.
Old Dec 21, 2004 | 08:10 PM
OBE1 95Z28's Avatar
You want to use distilled water, not tap water. Tap water contains minerals that will promote clogging. Some areas of the country, like Southern California, have worse water than other areas.
Old Dec 21, 2004 | 08:32 PM
96capricemgr's Avatar
I would recommend a anti corrosive/WP lube like Water Wetter or Purple Ice with the water.
Old Dec 21, 2004 | 09:36 PM
GreenDemon's Avatar
Ditto.
The system pressure should make it so you don't run into boilover problems, although you still won't have the capacity for heat if you were running a 50/50 mix.
Anything below freezing, though, and you will be out there with a bucket of hot water trying to unfreeze your radiator and your hoses. I've never done it, but I've heard stories.
Old Dec 22, 2004 | 03:02 AM
jkipp84's Avatar
Sounds great... I was just sharing what the various functions of coolant are.
blac94Z
Feb 15, 2021 09:43 PM
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
Boss002
Jul 9, 2015 03:33 PM
Blood type Z28
Apr 8, 2015 11:34 PM
