Using Stock Push Rods And Lifters On Cam Swap?
Old 09-20-2004, 06:45 PM
lt1_forever's Avatar
Is doing this ok? I think i'm going to buy the CC1418-16 MAGNUM SELF-ALIGNING ROLLER TIP 1.6 & CRN-10308-1 Chevrolet: 1992-99 350 LT1 with aluminum cylinder heads, valve spring and retainer kit. I have the CC305 cam. Any suggestion are fine. Thanks
lt1_forever is offline
Old 09-20-2004, 07:01 PM
dmoor88's Avatar
Re: Using Stock Push Rods And Lifters On Cam Swap?
some cars came stock with hardened pushrods. as far as lifters, you're taking a chance at collapsing a worn stock lifter. id take the preventative measures and order both hardened pushrods and at LEAST a new set of stock replacement lifters.
dmoor88 is offline
Old 09-20-2004, 07:03 PM
Z95m6's Avatar
Your stock pushrods should be fine. The stock lifters should be fine with that cam as it doesn't have very aggressive lobes.
Z95m6 is offline
Old 09-20-2004, 07:12 PM
Dave C. '97 Z28's Avatar
Stock parts will be fine for that as long as they're in good shape.
-Dave C. '97 Z28
Dave C. '97 Z28 is offline
Old 09-20-2004, 07:54 PM
my buddy also has some fuel injectors he said he would give me for free, i think there 36lb would this also help maxumize the cams effectiveness. Also would youo recommend a TB at the sametime
Old 09-20-2004, 08:34 PM
whatsup's Avatar
I installed the XE224/230 in early Spring. My car had 83,000 on it and I reuesd the stock lifters and pushrods. Many ( and I mean many ) 6000rpm pulls since install and have had no problems. 32lb inj. are way overkill for what you have. Stock 24# will support up to 400hp I think...please correct me if I'm wrong anyone.
whatsup is offline
Old 09-21-2004, 10:54 PM
1racerdude's Avatar
Stock lifter's and pushrods will be fine.
1racerdude is offline
Old 09-22-2004, 12:34 AM
Z-RATED94's Avatar
LT1 Forever, I have those same rockers in my garage now that I've up graded while do a H/C swap. If you what them, I'll sell them to you for $130 shipped. They have less than 3k on them.
Take care, Rick
Z-RATED94 is offline
oldschool
02-09-2016 09:21 PM
alphaauto
01-23-2015 07:42 AM
Brandon Wittmer
12-07-2014 12:15 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
chuyz28
11-25-2014 11:14 PM
Quick Reply: Using Stock Push Rods And Lifters On Cam Swap?
