used 1.6 Roller Rockers on stock springs and cam.
Old Mar 1, 2004 | 06:57 PM
hozb817's Avatar
I just got a set of used Crane Gold 1.6 Roller Rockers off ebay, and plan on installing them any day now. I am leaving the springs and cam alone. I have researched some info and I should pick up 10-15HP, better gas mileage, and between 1-2 tenths of my 1/4 mile time. Has anyone done this before?? If so what were your results?? Thanx for all the imput!!
Old Mar 1, 2004 | 07:31 PM
97WS6SCharged's Avatar
Definately replace the springs with some better ones.
Old Mar 1, 2004 | 07:56 PM
krispy's Avatar
get lt4 springs from sdpc2000.com, $33
http://www.sdpc2000.com/cart.asp?act...d=877&pid=2005
Old Mar 1, 2004 | 07:59 PM
Compstall's Avatar
At least get a set of springs for it. LT4's will be just fine, and they're cheap, as mentioned.
I gained 7 rwhp with 1.6's RR's and new valvesprings.
Old Mar 1, 2004 | 09:49 PM
OBE1 95Z28's Avatar
My friend did what you're about to do...10K miles later he busted off the ends of 2 of his stock pushrods from coil bind. He never did find one of the metal pieces
Old Mar 1, 2004 | 09:50 PM
That would be a sickening feeling.
Old Mar 2, 2004 | 01:08 PM
hozb817's Avatar
If I get the springs from sdpc2000.com do I need the valve spring cap kit they offer as well?? Thanx for all your imput!!!!
Old Mar 2, 2004 | 08:45 PM
truedualws6's Avatar
LT4 Hot springs can just replace the stockers w/o
any other stuff. Depending on mileage you may
want to consider new valve stem seals. And definately
check out the great info shoebox has on how to
do it.
Old Mar 6, 2004 | 05:24 PM
steve-d's Avatar
I was gathering the 1.6 rollers, hardened push rods and springs too. I was wondering if it would be a tremendous gain to also add the LT4 Intake? They aren't too expensive.
Would the gain by this swap of intakes be worth much in HP?
I'm not interested in changing the cam or adding headers.
Steve
'95 TA
Old Mar 6, 2004 | 06:34 PM
Steve
'95 TA
The LT4 intake is not a direct bolt on to LT1 heads. Even if it did, it would not result in a big improvement. It was made to compliment and fit the LT4 heads.
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
