urgent... 93 TA coolant flush
Old Dec 20, 2004 | 03:32 AM
fragenstein's Avatar
Only had car since April. Coolant smells like dead fish, and does not look GOOD.... what the swamp water. Ok, so, drained some out through radiator drain valve, only like a GALLON tho. Anyway... where EXACTLY are the knock sensor and block drain plug I am suppose to remove?
Thanks,
Drew
Old Dec 20, 2004 | 03:35 AM
GreenDemon's Avatar
Re: urgent... 93 TA coolant flush
http://www.shbox.com
Something in there should help you, either component locations or else how to section, etc., I'm not sure. I know it's there somewhere.
Old Dec 20, 2004 | 09:32 AM
OBE1 95Z28's Avatar
Syphon the coolant out of the overflow tank too.
Old Dec 20, 2004 | 10:00 AM
Bryan Smith's Avatar
http://shbox.com/1/block_drain_plug.jpg
http://shbox.com/1/ks.jpg
Old Dec 20, 2004 | 10:02 AM
94zgreenmachine's Avatar
The knock sensor is close to the oil pan rail on one side of the block and the drain plug is on the opposite side of the knock sensor.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
