Upgraded Mechanical Water Pump?
Old Mar 14, 2004 | 07:51 PM
zachattack45's Avatar
Does anyone know if somebody makes a Upgraded Mechanical water pump for the LT1? Dont want to have to worry about the meziere electric one failing and my car dying. So let me know if you guys know anything. If not what a bout a stock replacement? whats teh part number?
Old Mar 14, 2004 | 08:08 PM
GreenDemon's Avatar
I don't think anyone makes one because the water pump for us is so engine specific.
I would certainly be interested if anyone did, though, due to my concern about an electric one failing suddenly and my coolant temps skyrocketing.
Old Mar 15, 2004 | 09:13 AM
Aaronh's Avatar
Ditto, I considered an eletric but a quick search on here changed my tune pretty quickly. After the horor stories I've heard, there's no way in hell I do an electric
Old Mar 15, 2004 | 10:17 AM
T/A#4's Avatar
AMEN !
Old Mar 15, 2004 | 10:32 AM
anaik's Avatar
Stewart Warner is working on a higher flowing pump for the LT1, but do not say when it will be available.
http://www.stewartcomponents.com/htm....asp?m_id=1151
Old Mar 24, 2004 | 09:55 PM
Anyone know of somthing thats out now?
Old Mar 24, 2004 | 10:28 PM
anaik's Avatar
The electric ones flow more at idle, but have no comparision at 6K with the stock pump, More reliable also.
Old Mar 24, 2004 | 10:31 PM
Yea i know that, but im looking to see if any company made a better then stock mechanical water pump.
Old Mar 24, 2004 | 10:41 PM
jtk's Avatar
jtk
TPIS made a special belt driven mechanical pump for there own LT1 engine. I think they can make them up for people who want them, but I'm sure it costs alot
Old Mar 24, 2004 | 10:48 PM
anaik's Avatar
Why this interest.? to have the badest pump in town.
Old Mar 24, 2004 | 10:53 PM
Well im rebuilding my engine and im going to replace the pump, and i was seeing if any company made somthing better then stock, because otherwise im just going to get a new stock one.
Old Mar 24, 2004 | 10:59 PM
97WS6SCharged's Avatar
The stock water pump will work fine.
I very much doubt that flow numbers will matter all that much since most engines don't see 6k very often or for very long. Now if it were a silver star car or something along those lines, then it might make a difference.
Old Mar 24, 2004 | 11:12 PM
anaik's Avatar
I still see as a stock pump as more reliiable, even if one doesn.t run 6K at a constant.
Old Mar 24, 2004 | 11:44 PM
FastWhiteTA's Avatar
I just installed a Meziere Elec WP in my car, and I'm putting an LED inline so I can tell if it goes out or not, that way I know if my car is being cooled. And I've heard the Elec ones actually flow more than the stock ones even at 6k. Not sure how factual that actually is, but I'm gonna look up the #s sometime and I'll post back here. It did have a noticeably SOTP power difference though.
Old Mar 24, 2004 | 11:54 PM
jtk's Avatar
jtk
-I'm putting an LED inline so I can tell if it goes out or not-
that will tell you if your getting power to the pump but not if the pump is turning.
some one should make a two or three stage controler for these pumps. slow speed at idle, medium speed, and high speed at high rpm. that would make the pump last alot longer and reduce amperage draw
