UPGRADE fuel injectors????
Old Feb 16, 2003 | 05:07 AM
Dmx4ever3's Avatar
Question UPGRADE fuel injectors????
some one please tell me what comes stock on a lt1 95 camaro 6sp
i want to know if i need to upgrade my fuel injector i have stock in them now don't know what it is
LOOK AND SEE BELOW what i have done to my car tell me if it needs to be done and what what do good for me thanks guys
Old Feb 16, 2003 | 05:35 AM
joeSS97's Avatar
the stockers are 24lbs,yours are fine till you get some better heads and cam.
Old Feb 16, 2003 | 06:05 AM
Dmx4ever3's Avatar
Question
so i shouldn't go to 26 then right i have 72500 on my car now should i replace the stock with stock 24 or just leave on alone or get em cleaned i use spt fuel injecter cleaner like ever 3000 miles but i have the car since 52000 but should i do anything??? and what will a lt1orlt4 knock m do??
Old Feb 16, 2003 | 07:13 AM
Bryan Smith's Avatar
http://web.camaross.com/forums/showt...t=knock+module
Old Feb 16, 2003 | 11:13 AM
OneFlyn95z28's Avatar
I would just have the stock injectors cleaned
Old Feb 16, 2003 | 11:29 AM
RamAir95TA's Avatar
You won't need to replace the injectors until you max the stockers out (via heads/cam/boost/etc.). You won't need to replace them either, because injectors aren't usually a common part to fail. They don't wear like other parts.
AdsoYo
May 2, 2018 03:21 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
