Upgrade advice
Old Jan 10, 2007 | 06:09 PM
thegift's Avatar
Upgrade advice
Im in the process of making a few upgrades on my trans am.
Some of these upgrades include:
-K&N Air Intake
-Headers
-MadTunz
My question is are there any other upgrades that I should make that are often over looked but would improve the performance of the engine and help my engine cope with power upgrades.
Old Jan 10, 2007 | 07:14 PM
Mortify's Avatar
get Moroso CAI instead of the K&N, LONGTUBE Headers, Roller Rockers, Aftermarket Ypipe, Cat-back, and maybe step up to a large TB like 58mm, then get the tune
Old Jan 10, 2007 | 08:32 PM
reamo04's Avatar
on a 94, the tune is not necessary until u get into the motor.
I would get a lingenfelter CAI (165)
Longtube Pacesetter ceramic coated headers (390)
Catback (300)
y-pipe (idk price)
58mm TB(300ish)
1.6RR (idk price)
Old Jan 10, 2007 | 09:27 PM
Mortify's Avatar
ypipe (145-200)
1.6RR (200-400)
Old Jan 10, 2007 | 11:08 PM
LenT1's Avatar
Didn't think there was a big difference between K&N & Moroso.
Didn't think a 58mm throttle body was necessary on a mildy modded stock displacement engine.
Headers/exaust and a mail order tune would probably be good for the $$..
...Just my opinion based on what I have read.
Old Jan 10, 2007 | 11:11 PM
JohnnyPappis's Avatar
Your right a 58 mm would have no benifit at this point and the intake cant even use it without proper work so save your money there long tubes ORY and exhuast and a nice tune wouldent hurt because those long tubes tend to richen the car up a bit
Old Jan 11, 2007 | 12:23 AM
seawolf06's Avatar
TB would be pointless and I'd get gears before you get a tune. What suspension mods do you have? You'll prolly need some DR's, LCA's and reloc. brackets.
Old Jan 11, 2007 | 12:28 AM
sandman63's Avatar
How about some gears? The TB is useless.
Old Jan 11, 2007 | 09:34 AM
Z-RATED94's Avatar
-K&N Air Intake
-Headers
-MadTunz
What you have listed is a nice start. A little more air in and a little more air out is what makes more HP. And useing Ion as you mentioned to tune it is a good way to optimize those additions. Don't waste your money on a 58mm TB. And if you do add 1.6 rockers in the future make sure you at least upgrade to a set of Hotcam springs.
Old Jan 11, 2007 | 10:14 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I have a '94 Z28 that's essentially stock. What kind of gains can you expect if you simply put on a new intake and exhaust? And what if you then throw headers into that mix?
Assuming I ever get my car running properly, it's going to need a new exhaust system as we've cut off everything behind the catalytic converter. I'm certainly not going to put forth any effort to put that system back on the car. And putting on an intake would be a relatively easy mod. I might do some headers farther down the road.
Old Jan 11, 2007 | 12:43 PM
2000GTP's Avatar
The mods you have in store are a good idea. 1.6 roller rockers and some upgraded valve springs and pushrods would also be benficial. Don't forget to add a good catback in there as well. Also, you could do some cheap suspension upgrades such as lower control arms, relocation brackets, and replacement poly bushings for the remainder of the suspension parts.
97SSdude
Aug 21, 2015 09:36 AM
canuck94z28
Aug 19, 2015 05:50 PM
Rittmeister
Aug 7, 2015 01:13 AM
realistyc
Jul 28, 2015 07:32 PM
GT what?
Jul 14, 2015 10:17 PM
