Update of LT1 FAQ- need all your input, install guides and links
From: looking for a flow bench so Brook and I can race
hey guys-
ANY info you want on there, now is your chance to speak up.
Any FAQ's, general info, year specific info? link me now or forever answer the same question
any websites you want linked? install guides?
thanks
trey
edit:
the site will be www.LToneFAQ.com
thanks
trey
edit:
There is an install guide for "Hyperwhite Fog Lights" in my sig you can stick on there...and soon coming is the '93-'97 Lighting Guide Website...How soon will this be up? If it will be up before I get a chance to finish, then I can probably create a "Check Back Later" page for you to temporarily link to...
Originally posted by Timberwolf
doesn't Brent Franker already doa pretty good job of this?
this is more an FAQ. Just the common "whats an opti" and "what is jason cromers phone number" kind of thing as well as linking all the websites together
email me your links-
treyZ28@hotmail.com
differences between 4th gen years:
93, 94-95, 96-97, and cali 95s
hp ratings, why differences
m28/m29 versions of 93 t56
gearing and torq ratings for the t56 and A4
list of online perf. parts places: tbyrne, thunder, summit, jegs, ls1speed, fasttoys etc
rear gears available with which tranny, how to tell w/ option codes and the "lack of 1st gear selection"
what year SS started, who made them, and what it included (as well as info for the RS, WS6, Formula etc)
Header information:
http://eyeoutthere.tripod.com/headers_main.html
NewParts:
http://www.stranoparts.com/
http://www.racenet.net/
http://www.suncoastcreations.com/
http://www.FLPexhaust.com
http://www.jayfisherpontiac.com/enter.htm
http://store.summitracing.com/
http://www.rksport.com/rkstore/
http://www.jegs.com/
http://www.Jcwhitney.com
http://www.LMperformance.com
http://www.LGmotorsports.com
http://www.tbyrnemotorsports.com/
http://www.slpeng.com/
http://www.netgearhead.com/tran_reman.asp Transmissions!!
http://www.transmissioncenter.net/4L60E.htm Transmissions!!
http://www.hughesperformance.com/ Transmissions!!
Used Parts
http://www.speedautomotive.com
http://www.tacreationsusa.com/
http://www.billygrahamsfirebird.com/
http://www.mypartshop.com/
Tunning:
www.fastchip.com ed wright
New Parts (electric cutout)
http://www.quicktimeperformance.com/...atalog_lt1.htm
Dynomax catalog:
http://www.dynomax.com/documents/pas...ral_motors.pdf
Info/Guides:
Shoebox Tech Page:
http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html
crap loads of stuff:
http://www.bfranker.badz28.com/fbody/Guides.htm
LSD:
http://www.xious.com/camaro/install-lsd.html
https://www.mygmlink.com
Spring and Shock install:
http://www.houston-f-body.org/tech/shocks/index.htm
Camaro Headlight conversion
http://members.fbody.com/jcobz28/blue.html
Cam install
http://afrashteh.com/guide/install.htm
T-tops
http://www.dw-zone.com/t-tops/t-top.asp
tranny
http://web.camaross.com/bb/Forum1/HTML/097910.html
Firebird Headlight fix
http://www.bfranker.badz28.com/headlightfix/index.htm
Plugs
http://home.fuse.net/chocoruacal/LT1plugchange.htm
fuel pump
http://www.ufba.org/vids
OPTI
http://www.streetillusionsracing.com...ll/install.htm
Window motor
http://home.swbell.net/shoebox/windowmotor.html
1994 LT1 Torque Specs.
http://www.bfranker.badz28.com/fbody/torquespecs.htm
F-body Weights Page
http://www.bfranker.badz28.com/fbody/weights.htm
water pump
http://pages.sprint.ca/transamcenteral/files/water.htm
ignition switch
http://csce.uark.edu/~jgbertr/rb/ign...itch_repl.html
Fan switch mod
http://www.xious.com/camaro/install-fanswitch.html
Fan switch mod
http://eyeoutthere.tripod.com/fan_switch.htm
Fan switch mod
http://users.oco.net/xero/fanmod/
LT1 coil per cylinder
http://www.geocities.com/reilym/LTCC/
Appearance modification guide/database
http://www.bfranker.badz28.com/appearance/
LS1 brakes on LT1
http://www.fbody.com/tech/details.cgi?id=30
Part numbers:
LS1 Drive shaft: 12564003
LS1 Caliper bracket: 18026163
LS1 guide pins: 12530697
LS1 Front Guide pin seals: 18026151
LT1 axial shaft seal: 26029139
LT1 pinion seal: 26026792
Stereo:
Wire Codes
http://www.autotoys.com/New_Tech/Wir..._geo_radio.htm
Wire Codes
http://carstereohelp.com/wireharnessPontiac1.htm
Wire Codes
http://carstereohelp.com/wireharnessPontiac2.htm
Steering wheel controls:
http://www.wholesaleaudio.com/pac.html
Connections:
Dal Slabaugh: 1-800-362-9494 ext 501
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
Jason Cromer: 1-877-726-8295
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Sam Smith: 1-800-395-1440
email: samsmith@fairwaychevy.com
Fairway Chevrolet Las Vegas, NV
Rre-programing of 1996 and earlier 4th gen f-body remote.
1. Locate the Data Link Connector (under the dash near the steering column).
2. Attach a jumper from terminal 8 (8th pin from the left on the top) to terminal 4 (4th pin from the left on the top).
If you have done this properly, the doors should lock and unlock after less than about 5 seconds.
3. Hit any button on the first transmitter. Doors will lock and unlock when transmitter is accepted.
4. Hit any button on the second transmitter. Again, doors will lock and unlock when transmitter is accepted.
5. Remove the jumper from the DLC and the transmitters should both operate correctly.
Note: If you remove the jumper before programming both transmitters, only the first will work and will fill both the slots of acceptable transmitters. Also, the transmitters will not work until the jumper has been disconnected.
Option Codes:
GU3 = 2.73's
GU4 = 3.08's
GU5 = 3.23's
GU6 = 3.42's
G80 = posi
NewParts:
Used Parts
Tunning:
Dynomax catalog:
Info/Guides:
Shoebox Tech Page:
LSD:
Cam install
T-tops
tranny
Plugs
fuel pump
OPTI
Window motor
F-body Weights Page
water pump
ignition switch
Fan switch mod
Fan switch mod
Fan switch mod
LS1 brakes on LT1
Part numbers:
Stereo:
Wire Codes
Wire Codes
Wire Codes
Connections:
Option Codes:
GU3 = 2.73's
GU4 = 3.08's
GU5 = 3.23's
GU6 = 3.42's
G80 = posi
Stereo Theft Lock
NOTE: If you allow more than 15 seconds elapse between steps, the radio will
automaticly revert back to the time, and you'll have to start over from step
4.
1) figure out a secret # from 000-1999 and write it down somewhere.
2) turn the ignition to ACC or RUN position.
3) Turn the radio off
4) press the 1 and 4 buttons together (on the preset buttons). Hold them down
until --- shows on the display. Next, you will use the code you wrote down.
5) press MIN and 000 will appear on the display
6) press MIN again to make the last 2 digits agree with your code.
7) press HR to make the 1st one or two digits agree with your code.
8) Press AM-FM after you have confirmed the code matches the secret code you
have written down. The display will show REP to let you know that you need to
repeat steps 5 through 7 to confirm your secret code.
9) Press AM-FM and this time, the display will show SEC to let you know that
your radio is secure
Unlocking Theftlock after a power loss:
1) LOC appears when ignition is on
2) Press MIN and 000 will appear on the display
3) Press min again to make the last 2 digits agree with your code.
4) press HR to to make the first one or two digits agree with you code.
5) Press AM-FM after you have confirmed that the code matches your secret code.
If you enter the wrong code 8 times, INOP will appear on the display. You will
have to wait an hourwith the ignition on before you can try again. When you try
again, you will only have 3 chances to enter the code again until INOP appears
again.
Disabling Theftlock:
1) turn the ignition to ACC or RUN position.
2) Turn the radio off
3) press the 1 and 4 buttons together (on the preset buttons). Hold them down
4) press MIN and 000 will appear on the display
5) press MIN again to make the last 2 digits agree with your code.
6) press HR to make the 1st one or two digits agree with your code.
7) Press AM-FM after you have confirmed the code matches the secret code
The display will now show ---, indicating the radio is no longer secured...
Theftloc Bypass *****
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 202107, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
4.
again.
i've been waiting month with anticipation to give this link away
http://www.automotiverebuilder.com/ar/ar99928.htm
its very resourcefull
oldschool
Feb 9, 2016 09:21 PM
sc93
Jul 26, 2002 02:02 PM
