unhooked sensor
Old Feb 7, 2004 | 05:32 PM
  #16
polcat1p's Avatar
On the 93 cars the air pump is located on the chassis, under the abs. On the 94 cars it is located on the engine block, under the coil. Right in front of the driver side fan. There should be a hose going to it. Almost looks like a smalled rad. hose. If you just bought the car, the other owner might have deleated the air pump.
Chad
Old Feb 7, 2004 | 06:00 PM
  #17
BiGGinZ's Avatar
I did get the car a little bit ago but I think the air pump is there, but it already has a sensor in it.
Old Feb 7, 2004 | 06:01 PM
  #18
BiGGinZ's Avatar
I hope I can get a pic up later.
Old Feb 7, 2004 | 07:21 PM
  #19
BiGGinZ's Avatar
I have a pic, not a good one by any means. It is very hard to get in there and take a pic, plus I dont have a digital camera. If anyone wants it just say so and leave your e-mail and I will send it to you.
Old Feb 9, 2004 | 08:22 AM
  #20
RENE95Z's Avatar
http://shbox.com/1/temp_sensor1.jpg
Here is a pic of the airpump from underneath. (Courtesy of Shoebox's Site) As mentioned above, a previous owner could very well have deleted and left the plug hanging.
Old Feb 9, 2004 | 04:21 PM
  #21
BiGGinZ's Avatar
What would that do if they deleted it? Is that hurting my car?
Old Feb 9, 2004 | 07:01 PM
  #22
RENE95Z's Avatar
No, it is not hurting your car. I deleted my air pump also. Just need to make sure you have a good fuse in or you will set off the SES light. The air pump is only used primarily at start up for about 3-5 minutes to help heat up the cat or cats, then it basically becomes useless dead weight until you let the car sit for awhile.
98-LS1Z28
Sep 8, 2015 03:12 PM
MDZ28
Sep 7, 2015 09:16 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
