Are underdrive pulleys safe?
Been considering doing a pulley swap for a while but I have been hearing different things. Is it true that the pulleys you get from companies lile March (just pulling a name out of my head) are cheaply made and unbalanced? Do you have to replace all the pulleys or just the crank and alt pulley? In doing this mod do you shorten the lifespan of things like the alt and power steering pump?
Re: Are underdrive pulleys safe?
I have the March crank pulley only on a 6spd. It still charges fine. The alternator, a/c and power steering pump turn slower which is easier on them. With the March pulley you still have to bolt the original balancer back on with it. ASP has one that doesn't need the balancer. I would go that route if I was doing it again.
The March piggyback pulley I have on now runs just fine, balance is perfect. I would watch out for no name brand pulleys.
I bought an ASP but I have not put it on yet. I bought it cause it will be lighter than the piggyback style which is heavier.
This March pulley with hardware will be for sale for $50.00 shipped if you are interested.
Piggy back means it actually bolts where the balancer used to, then the balancer bolts to it. IMO though, pulleys on an Lt1 are a waste of money. Most of the drag coming from belt driven accessories comes from the water pump and the power steering. Lt1's lack of a belt driven WP kind of defeat the purpose of ud pulleys... Ive yet to see anyone with real world gains with them to be honest.
The old piggyback ones are worthless tho, IMO.
RUENUF
Mar 13, 2016 03:37 PM
Aug 7, 2015 08:52 AM
