Underdrive pulleys
Old Nov 26, 2003 | 03:21 PM
  #16
Shelldust's Avatar
Originally posted by fastcamz28
Is that the underdrive crank pulley (34%) from LS1 Speed, Inc. or the underdrive harmonic balancer (25%). I want to replace the OEM damper. Right now I have an underdrive pulley behind the damper (harmonic balancer).
Thanks!
Thats how mine is, its behind the damper.
Old Nov 26, 2003 | 04:16 PM
  #17
Heatmaker's Avatar
Advanced Member
Originally posted by WS6_Keith
Also remember that slowing down the accessories slows down the PS pump. That's a decent draw there, and that pump will cavitate over 3500rpm engine speed. By slowing it down, and stopping it from cavitating, you also reduce it's propensity to boil the fluid - which is a problem if you road race or drive very aggressively.
Slow down kieth the drag from the pullies isn't that extreme. I've had no problems or differences at all in the steering. The only real problem you'll have with the larger pulleys is if you have an after market stereo system that's pulling awsome watts or something.
Old Nov 26, 2003 | 04:25 PM
  #18
WS6_Keith's Avatar
That was my whole point. The biggest benefit I saw was slowing down the PS pump. Above 3500rpm with stock pullies, you cavitate the pump which eventually will boil it over (been there, done that). I ended up putting a PS cooler in my car as well, but slowing it down helps too.
Of course, you will only experience this problem during extended high-rpm use, like the Silver State Classic that I run and perhaps some hard road course sessions.
Old Nov 26, 2003 | 05:26 PM
  #19
95BlackTA's Avatar
If your car is a daily driver, especially in stop and go traffic, dont put it on. If you only drive on the highway, put it on.
I have one, and hate it because when im sitting still it kills the battery...especially when you have a 1200 watt amp you want to bump from time to time, oh and the air....
I might even take mine off....
Old Nov 26, 2003 | 05:40 PM
  #20
WS6_Keith's Avatar
No, just get the March kit with the Alt pulley too. I have that kit with no problems. Got around 1200w in my ride too.
Old Nov 26, 2003 | 05:54 PM
  #21
1badasZ's Avatar
Thumbs down
i had one and took it off and have been happy every since. i got sick and tired of having to be jumped off and putting it in neutral in traffic to keep my volts up. the few horses just wasnt worth it to me.
Old Nov 26, 2003 | 05:57 PM
  #22
Heatmaker's Avatar
Advanced Member
I got the march kit from thunderracing.com I think you need the new Altinator pully for the kit.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
