Underdrive pulley
Old Nov 17, 2016 | 07:15 PM
wheelliftnpony's Avatar
Underdrive pulley
So I did a few searches, and got different results. Here's what I got going on.. I put an aluminum ud pulley on a few years ago.. 6 or 7.. I'm in the middle of an opti install right now and I'm coming across some things about having to use your factory crank pulley on top of the ud pulley? I was under the impression that these pulleys were neutral balanced, so I never even thought this was necessary. Now like I said, this pulley was installed years ago, and I haven't had any issues regarding it. I guess my question is how important is having the factory pulley on there? Do I need to go to a junk yard and try to find one? (Mine is long gone)
Old Nov 17, 2016 | 09:24 PM
Re: Underdrive pulley
It's a harmonic dampner-not a balancer. It cancels out vibrations harmful to the crank. Yeah, should be on there.
Old Nov 17, 2016 | 09:32 PM
Good enough, thank you
Old Nov 18, 2016 | 06:08 PM
bw_hunter's Avatar
Better to buy a new one....anyThing in a junkyard is at least 19 years old.
