underbody ram air
Old Jun 3, 2003 | 09:07 PM
ztwenty8's Avatar
underbody ram air
ok i wanna do a cowl hood or big block hood, the problem is i cant do ram air then.
so ive seen other cars with under body ram air kits like the mustangs and some imports, well ive been searching all over for a kit but i can find one
any body got ideas or sites let me know
Old Jun 3, 2003 | 09:19 PM
All4Chevy's Avatar
Cut out the plastic guard underneath your intake filter on by your drivers side wheel....then using aluminum siding as i used, or anything that you can bend and will stay in place, bend into a scoop that can be screwed up from underneath. Easy to do, just gotta find a good material to use.
Bill
Old Jun 3, 2003 | 09:40 PM
Aeroforce1's Avatar
Go to Home Depot, Loews or the harware store and get a dryer vent. Trim down the through the wall pipe, Cut the plastic gaurd, Slide the vent in and srew it on. A little paint and your done.
Old Jun 3, 2003 | 10:34 PM
ztwenty8's Avatar
i got the idea of the dyrer house
i might have more difficulty with the scope you guys made your own or is there something i can use to work as the scope?
Old Jun 3, 2003 | 11:15 PM
Bud M's Avatar
First you need to get a CAI. Then make a scoop.
Old Jun 3, 2003 | 11:53 PM
ChuckZ28's Avatar
Yeah I just used a peice of alumimun flex tubing from a hardware store ran it to the filter. I used zip ties and a screw to hold it in place. It cost $4.50 and cut 3 tenths off and added 1mph.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
