Type of rockers with LE1 head & Cam
Old Jul 15, 2007 | 01:51 PM
DSM PImp's Avatar
I just got my LE1 heads. I also have a comp cam with gross valve lift of int .541 exh .537. for my 383. I was told that the stock rockers will not work with my cam. Elliott said the following,
"I do not need the rockers and they will NOT work with any of my cams (or hardly any aftermarket cams at all for that matter). You will want to get a roller rocker and some GOOD pushrods (at least some $80 Trick Flow pushrods) to stand up to the cams lift, ramp speed, RPM range and the spring pressure."
I buddy of mine is using stock rockers with his cam, but it is not as aggressive. I am going to call my machine shop when they open on monday and see what they say. But what do you guys think. yes or no on the roller rockers.
Also still not sure what pushrods im using.
Old Jul 15, 2007 | 02:01 PM
urbaNHunter44's Avatar
Using comp cams 1.6 promags, no problems. They're pricey though.
DEFINETLY use aftermarket roller rockers though, don't even bother with the stamped steel POS
rocker arms is a virtual necessity when swapping cams.
Old Jul 15, 2007 | 02:23 PM
dangalla's Avatar
just my .02 cents
Comp rockers 1305-16 (pro mag, 7/16, 1.6, nsa)
Comp pushrods 7939-16 (chromolly 7.150) but length should be checked first
Arp studs 134-7103
Trick Flow guide plates 30400623-8
Old Jul 15, 2007 | 02:27 PM
DSM PImp's Avatar
as far as pushrods i just found these that ill prob get. comp cam 7940-16.
So do you guys think that the stock rockers wont last.
Old Jul 15, 2007 | 02:33 PM
dangalla's Avatar
call lloyd, ask him what size he recomends in his heads, and no, do not use your stock rockers
Old Jul 15, 2007 | 03:14 PM
speed_demon24's Avatar
Originally Posted by dangalla
just my .02 cents
Arp studs 134-7103
Get the trickflow pushrods instead of the comp hi-tech ones, they are made by the same place as the comps and they are the same exact pushrod, just $60+ cheaper ($85 vs $155). I have some trickflow 7.15" pushrods for sale for $60 shipped if you are interested.
Old Jul 15, 2007 | 04:18 PM
DSM PImp's Avatar
man ur an hour to late. I would have taken them, but i just bought the comp cams (but i paid 100). all well.
So i guess the answere here is buy the roller rockers
Old Jul 15, 2007 | 04:27 PM
dangalla's Avatar
yes, i highly recomend Non-selfaligning with guideplates, and 7/16
Old Jul 15, 2007 | 04:58 PM
DSM PImp's Avatar
u think the stock guideplate wil be fine?
Old Jul 15, 2007 | 05:19 PM
MeanGreen97Z's Avatar
There is no stock guideplate. You need to purchase those separate.
Old Jul 15, 2007 | 05:54 PM
DSM PImp's Avatar
yea ignore my last post
Old Jul 15, 2007 | 08:42 PM
wrd1972's Avatar
Uh Huh
Old Jul 16, 2007 | 04:50 PM
DSM PImp's Avatar
what do you guys think about COMP CAMS MAGNUM ROCKER ARMS SBC SELF-ALIGN 1.5 1417-16???
FYI Cam valve lift int .541 exh .537
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
