Two Questions- Tires and Heads...
Alright I have two questions:
1. I need new rear tires, Does anyone have good links for fair priced tires? What is the biggest size I can get? I have 16 by 8 rims. I want something that will get some traction, but I am not to familiar with tires so I need some help in deciding. Nitto, bf goodrich, other options?
2. Im stuck on my heads and cam. I have three options. A.I. with the sale, which I dont know if I can afford right now, well I can afford them, but my dad has to help me out with a few hundred dollars. I emailed a local performance shop and they want 2300 for stage 2, but I dont really want stage 2, unless everything Im looking at is stage 2. How does Lloyd compare to someone like A.I.? He gave me a good price and I wouldnt be pressured by a sale.
The best all around tire I have found is the Nitto 555Rs, they have a soft compound so they hook well and yet they have great wear. The BFGs wear out too fast but they hook a little better. To me if you will drive it on the street a whole lot its a no brainer get the Nittos.
I have read a lot about Phil but don't know anyone personally with his heads. I do however know someone with a set of Lloyds heads and he loves them. Through an auto with a very small cam this kid made almost 400rwhp. IMHO you will be happy if you choose either of those two.
I wouldnt worry about 245-50/16 nittos. They should be fine, but then again some 10 bolts are going 10s and others break on low 13 second runs. As a reference I run 315 Nittos on my stock 10 bolt and have had no probs to date.
How is jegs with shipping and customer service? I never really see anything about them, but they have what Im looking for.
Rim: 7''-8.5''
Dia.: 25.67''
Sec. Width: 9.8'' on 7.5'' Rim $141.99
Rim: 7''-8.5''
Dia.: 25.67''
If you want something comparable to the other options you're considering, we do have an Econoport package that's pretty cheap & easily on par with most any of the "full port/Stage 2" packages out there.
Honestly though... cz28 is a great resource, I'd simply search for actual dyno graphs & go from there with whatever suits you best
Good Luck!
-Phil
Edit: D'oh, typo
Good Luck!
-Phil
Edit: D'oh, typo
Rim: 7''-8.5''
Dia.: 25.67''
Rim: 7''-8.5''
Dia.: 25.67''
How are Kumho Ecsta Supra 712 tires? They are only a 100 a tire and I remember reading something about them but I forget what it was. Any word on these? Ordering tires any minute!!!
Just ordered Nitto 555R tires and front powerslot rotors and Hawk pads from tbyrne. Man what a steep price for things. Im hopping maybe they will let me get in late on that 10 % of all tires...its worth a try. Thanks for all the replies. Say bye bye Mr. Stock Rear!!
I'm the guy with the Lloyds heads and a small cam(~220/226) that KCformula was talking about. I put down 384rwhp before tuning and with timing pulled at wot because of a weird knock problem. It should be 400rwhp no problem with the problems fixed and with it tuned. I ran my first pass on the setup Sunday and ran a 12.12 with a 1.68 60ft.
