Two injector aren't firing...36#er's
Well i installed my 36 lber's today that i bought from someone here on the board and for some reason two aren't working! I knew it wasn't running on all 8 cylinders so i pull the clips one by one to see what was up and sure enough when i pull clip #4 and #5 there wasn't a change in idle at all! What could be causing this? I check to make sure they were getting power and they are! Could they be clogged or something, or can an injector just quit working? I need help quickly, suppose to go to the track tomorrow! Thanks
Re: Two injector aren't firing...36#er's
How do i do that? I didn't have a mulitmeter! All i had was one of the cheap things that show if there is getting current and a little led lights up!
I'll try switching them around tomorrow morning! Any idea why this might be happening?
Yes earlier #5 and #4 were not working so i took those two out and put them in slot #6 and #8 and now #6 is working but #8 still isn't!
Tried...still isn't working
putting the stock ones back in now!
Gonna try and mess with the tune for now to see if i can fix the high rpm miss...that's the whole reason i got new injectors cause mine were hitting """113%""" DC "according to datamaster right when it was missing!
Try tapping on the injector with something hard. I used a wrench on mine. When I did my swap, none of them were working. I tapped each one and when I did, they started working fine. The were apparently gummed from sitting too long.
Tap on it pretty good and see what happens.
