Turn signals not blinking? Any ideas?
Old Mar 2, 2004 | 04:51 PM
Black94mula's Avatar
I actually just got the car back from the body shop, so i'm thinking they might be the culprit. When i use the turn signals, the arrow lights up, but they dont' blink. I went around the car and the bulbs light up and just stay lit. Any ideas? I looked at the fuse panel and the relay and fuse panel under the hood and didn't find a fuse for the blinker.......
Old Mar 2, 2004 | 05:06 PM
cmbob67's Avatar
YEA, I'm having the same problem. Check to make sure all of the light bulbs are good. If one is out then the hole thing gets messed up. After that I'm lost. All my bulbs are workin OK.I'm curious to see what the problem is so I can fix mine. Good Luck
Old Mar 2, 2004 | 05:21 PM
Tair's Avatar
change out your turn signal flasher. My turn signals used to stay on constantly instead of blinking and this fixed my problem. The picture below is from Shoebox's website. You have to take the driver's side bottom dash panel off to get to the flasher. The thing on the top of the pic is the steering wheel, just so you know the orientation of the pic. Flasher should run you less than $5 at any Napa, Checkers, Autozone, etc.
http://shbox.com/1/flashers.jpg
Old Mar 2, 2004 | 05:24 PM
Thanks i'll try that..
Old Mar 2, 2004 | 06:04 PM
Bersaglieri's Avatar
That worked for me also, replace that.
-Dustin-
Old Mar 3, 2004 | 12:21 AM
ok they work now, although they seem to blink a little faster than normal....
Old Mar 3, 2004 | 01:45 AM
TimbrSS's Avatar
You probably got the high performance flasher.
Old Mar 3, 2004 | 01:47 AM
InjectedSS's Avatar
Try running synthetic blinker fluid from now on... I did and I dropped 2 tenths in the 1/4
Old Mar 3, 2004 | 01:49 AM
Zack's Avatar
when i got my car back from the body shop, my left turn signal would just stay on, I checked out the bulb, IT WAS THE WRONG ONE!. easy fix
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
