turn signal stopped working
Old Apr 21, 2003 | 07:02 PM
speedcrazy's Avatar
hey guys a little problem. hopefully someone can help me out. my drivers side turn signal stopped working. basically it has stopped blinking. green arrow inside car doesn't blink and lights outside dont blink they just stay solid. passenger side works like normal and everything else works fine. drivers side just wont blink. any ideas what it would be. wouldn't the left and right side flasher be controlled by same device?
thanks guys
Old Apr 21, 2003 | 07:06 PM
95ChameleonTA's Avatar
check your flasher....its under your drive side dash near your console.
Old Apr 21, 2003 | 07:22 PM
Fastbird93's Avatar
I second that! It was my problem.
Old Apr 21, 2003 | 07:26 PM
Probably a burned out high filament. Try your hazard flashers and see which bulb does not flash, then replace that one.
Old Apr 21, 2003 | 07:56 PM
speedcrazy's Avatar
thanks guys
that flasher controls both the driver and passenger side?
Old Apr 21, 2003 | 08:24 PM
both is under the driver side, the hazzard flasher is under the steering wheel and the turning flasher is near the console.
Old Apr 21, 2003 | 09:11 PM
I mean replace the BULB that does not flash.
Old Apr 21, 2003 | 10:16 PM
speedcrazy's Avatar
dont think its the bulb dude cause front and back lights dont flash and green arrow inside doesn't flash.
Old Apr 21, 2003 | 10:27 PM
Sorry, but that is exactly the symptom of a burned out bulb element or bad bulb connection. The flasher needs the resistance of the elements in all the bulbs in the circuit to make it flash. If one of the elements is out, then the flasher's bimetal strip will not heat up enough to cause the "make/break" function that causes the flashing.
Old Apr 21, 2003 | 10:40 PM
speedcrazy's Avatar
what about if the hazzard works perfectley fine. all 4 lights flash.
Old Apr 21, 2003 | 11:02 PM
Then try replacing the turn signal flasher (though I can't see why it would affect only one side, since the same flasher works both sides) or check the wiring connections at the base of the steering column.
Old Apr 21, 2003 | 11:17 PM
Mine did. I thought the same thing too.
Old Apr 22, 2003 | 05:48 AM
speedcrazy's Avatar
cool thanks again guys. ill check connections and then the flasher. if i have to get a new flasher are they pretty cheap?
Old Apr 22, 2003 | 07:00 AM
Fastbird93's Avatar
I think I paid something like $2.50 for mine from Autozone if I remember right. It's been awhile though, but they're not expensive at all.
Old Apr 22, 2003 | 07:18 AM
Racer 1283's Avatar
Mine did the exact same thing. I replaced the socket, because the ground contact was fugged up. The one I replaced was the socket closest to the middle of the car. I got the new socket at Car Quest, and it only ran me 6 bucks.
