Turn signal doesnt work
Old Feb 20, 2003 | 01:41 PM
LT1 Bunny's Avatar
okay, the left turn signal works but the right doesn't work. I have already replaced the side marker where the turnsignal is...but I have no idea what else it could be! Please help! When I do turn on the right turn signel, sometimes it works and other times it very very slow. But the left side works absolutly fine.
Old Feb 20, 2003 | 03:10 PM
Carefully check every bulb and socket. Sometimes corrosion will cause a problem even if the bulb is good. If you have to clean them up, use some bulb or lithium grease when you reinstall the bulbs. That will help keep moisture out.
Old Feb 21, 2003 | 01:20 PM
danicus007's Avatar
I ran into this same problem. It turned out to be the DRL (daytime running lamps) module. It cost me about $40 from Jason Cromer but it fixed the problem right up. This is after I changed the bulbs and then changed the bulb sockets as well. The DRL module is located right behind the stereo and is attached to a bracket. Slides right off. Good luck.
Old Feb 21, 2003 | 04:00 PM
Rearpl8tsinsite's Avatar
Mine did the same for a while then just stopped working all together. Noticed my brake light out on the same side. After checking fuse (which was fine) I replaced what looked like a perfect bulb (listen to shoebox with the lithium grease) and it solved both problems brake light and signal.
Old Feb 21, 2003 | 07:24 PM
robob's Avatar
'96 F-body had daytime running lights? Mine doesn't and I bought it new.
Old Feb 21, 2003 | 09:35 PM
LT1 Bunny's Avatar
Okay, I checked out the sockets and the bulbs....in the back. The front turn light works fine...but I am still stumped! What else is next? Could it be a relay?
Old Feb 21, 2003 | 09:42 PM
Do you mean the back is not lighting up, but the front is? Is the light solid or blinking?
You might check the long connector that is attached to the RH side of the base of the steering column. Make sure it is squeezed together well.
Old Feb 21, 2003 | 11:38 PM
LT1 Bunny's Avatar
No I mean that its lighting up and everything like that but what it's not doing is staying consistant. Meaning that you'll hear the relay click.........9 seconds later it clicks again. Instead of a normal operation...click, click, click...and so on. And the left one (drivers side) works and the passenger side doesnt work.
Old Feb 21, 2003 | 11:40 PM
LT1 Bunny's Avatar
Robob...yes mine has DRL's I hooked them up to be like that because I like them. And I've had the DRL's for over a year now.
Old Feb 24, 2003 | 01:13 PM
danicus007's Avatar
If you know anyone else w/ a camaro w/ DRLs...try swapping that module out and see if it fixes it.
Old Feb 24, 2003 | 01:57 PM
LT1 Bunny's Avatar
The only thing is that my 96 doesnt have drl's. But I used a guide I found on the internet that uses two relays so your able to have the brighter lights on. Rather than the having the dim lights. I forget where the install page was but basically all it said to do was get two relays so you are able to have the turnsignal one...and then when they are in use they go bright to dim. Stock its dim to bright. But there is nothing wrong with the relays because if there was then the drive side turn signal wouldn't work either. I know it sounds confusing....but I think it's because there is water damage to the elctrical sockets. I going to fix that problem becasue my lights assemblies came in today and I'll have to see if it fixes the problem...my old ones are cracked pretty bad and water gets to the lights. So hopefully this fixes my problem! Thanks everyone! Keep coming with suggestions!
Old Feb 24, 2003 | 06:07 PM
LT1 Bunny's Avatar
I sprayed so,e lith. grease in there...changed the bulbs and now its dark outside. But that still didnt do anything. Tomorrow though I am going to check that long connector on the right of the seering column like shoebox said. It actually worked again, and I noticed that the relay flasher thingie under the steering wheel wasnt making a click noise. but for the left side it did. Is it possible that one side can work and the other side is urnt out on the flasher? I am diff. going to look at it again tomorrow.
Old May 21, 2003 | 09:12 AM
DPassion's Avatar
Turn Signals
I currently have the same problem with my turn signals. Did you happen to fix yours? If so, what was the problem and how did you fix them? Thanks.
DP
Old May 21, 2003 | 03:17 PM
LT1 Bunny's Avatar
Hey, it turned out that advanced auto parts didnt give me a flasher bulb. The easiest things I swear!!!
Old May 21, 2003 | 08:41 PM
DPassion's Avatar
Question Some turn signal questions
So what you needed was a flasher bulb? Could you explain?
Do you think there is something wrong with my bulbs? wiring? or relays?
Last, but not least...I have turn signal lights on my mirrors and was wondering if you knew what I needed to wire it so that I can have the signal lights alternate with the mirror lights? Thanks!!!
