tuning or not
Old Oct 27, 2003 | 10:05 PM
CodysRedZ's Avatar
tuning or not
I have had my car tuned by ed wright in the past when i had just bolt ons. Since then i have added a 3000 stall converter and 3.73 gears. Would retuning benefit my car and all? I dont care about the mph being jacked up.
Old Oct 27, 2003 | 10:07 PM
madwolf's Avatar
Did you ever go wide open throttle with the 3.73 gears? Normally it should hit the rev limiter, or at least it will shift later than it should. (past your current powerband)
Old Oct 27, 2003 | 10:18 PM
CodysRedZ's Avatar
no i havent put them in yet they are sitting in my room. But, i will be putting them in within the week.
Old Oct 27, 2003 | 10:19 PM
madwolf's Avatar
Yep, you'll need it recalibrated or else your shift points will be messed up and you'll be hitting the rev limiter.
Old Oct 27, 2003 | 10:20 PM
CodysRedZ's Avatar
I just read another post about you. Your stuff looks awesome. Ive had my done by ed wright. recently i had it dynoed and it was running way lean. like 14.5 afr. Isnt that way too lean for me? All i have is bolt ons. I didnt see again gain or feel any gain from his tuning. You say u will guarantee your tuning? Can u tune it after its already been tuned by ed??
Old Oct 27, 2003 | 10:26 PM
madwolf's Avatar
14+ is definetely lean. If you provide the graph, I can get it very close for you. (12.5-13 is where it should be)
I can overwrite Ed's program, no problem there.
And yes, I do guarantee my tunes, as long as your car doesn't have bad plugs/wires or other stuff like that. (not saying that it won't work, it's just that it won't provide the gains you're looking for since the power wasn't there already)
Old Oct 27, 2003 | 10:29 PM
CodysRedZ's Avatar
Awesome. I dont have the sheets anymore. it was 14.5 exactly. I am going to get it redynoed and get the sheets and then send them to you. What should the afr be for me? I have CAI, LT headers, no cats, exhaust, and tuning pretty much, and a converter. Also, if it was 14.5 what kind of power loss was i looking at??
Old Oct 27, 2003 | 10:35 PM
madwolf's Avatar
12.5 - 13 is optimum for power. Leaning it out more may deliver the same horsepower but it's not very safe for the engine. You may have lost 5-10 HP though at most, if you lost any.
Was it 14.5 all the way or only at certain points?
If it was 14.5 only at the begging, that is normal.
Old Oct 27, 2003 | 10:37 PM
CodysRedZ's Avatar
it was 14.5 all the way through
Old Oct 27, 2003 | 10:38 PM
madwolf's Avatar
Hmm... you might have a fuel delivery issue. I really don't think Ed leaned it out that much. How much HP did it put down?
Old Oct 27, 2003 | 10:44 PM
CodysRedZ's Avatar
263 rwhp. im not quite sure on the torque. its been a little while. It just feels like it has not pull upper end anymore. I dont know what the deal is. I will dyno it again and let u know i guess.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
