Tuning And Nitrous Question!
Old May 27, 2004 | 12:48 PM
Kryckter's Avatar
I have all the mods in the sig. Still have the cam and tuning. I have recently bought a Nitrous Express wet kit. I have already changed the plugs to some NGK TR6's. My main concern will be the timing advance. I have raised the compression a little bit since the heads were resurfaced during a rebuild. I have a PCM4Less tune on the car and I believe that his tunes advance timing from stock. Will I be alright to run the car with a 150 shot. The air fuel ratio is perfect on a Wide Band O2 reading. I was told around 100 shot but I may need to take some timing out for the 150. The NX kit says that you may have to take out timing for the 150 shot. I have heard alot of different ideas and wanted your guys opinions.
Thanks In Advance
Old May 27, 2004 | 02:44 PM
OBE1 95Z28's Avatar
Your tuning won't know when you're running nitrous or not. The work around is to buy an aftermarket ignition box that has a timing retard feature. You can then adjust the timing and have it only retard timing when the nitrous is activated. You will of course adjust your air/fuel ratio by changing your jet sizes. The recommended jets are based on a stock engine and PCM.
Old May 28, 2004 | 02:08 AM
Kryckter's Avatar
Well I was wondering if it would be alright to spray the 150 shot on the tuned car. I know it was tuned for an all motor application so do I need to get it re-tuned. How much would be considered safe with a little higher compression and a tune?
Old May 28, 2004 | 02:36 AM
97WS6SCharged's Avatar
You shouldn't need to change the tune. The nitrous and fuel solenoids will add the appropriate mixtures of gas and well... "gas", and a retard (duh!) box will pull a user determined amount of timing from the motor.
How much did you have the heads surfaced? I doubt it was enough to affect the compression very much.
Old May 28, 2004 | 04:11 AM
roadtrip120's Avatar
he raised the compression one point(1.0)
MadMav
May 25, 2015 09:35 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
