Tuning Changes For Just A Fuel Injector Size Upgrade?
Old Mar 27, 2012 | 12:52 PM
97 6SPEED Z's Avatar
Question Tuning Changes For Just A Fuel Injector Size Upgrade?
Okay, first off I posted this question on the "Computer Tuning & Diagnostics" forum, and the link is here:
https://www.camaroz28.com/forums/com...hanges-856625/
but, it was suggested that I post this here also.
Here's my question ........ if you already have a decent "mail order" tune for your somewhat modded car, (see signiture), and you just want to change from Ford SVO 30 lb/hr to 42 lb/hr fuel injectors, nothing more .......... what all is required to be changed in your current PCM tune?
Put another way, is computer re-tuning for ONLY an injector size change easy to do?
TIA for any replys in this forum.
Old Mar 27, 2012 | 01:12 PM
mrmint69's Avatar
Re: Tuning Changes For Just A Fuel Injector Size Upgrade?
Super easy for the programmer, but they will probably charge you the full amount even though its a simple retune. Personally, I would hold off unless the current injectors are not big enough for the setup or not working correctly.
Old Mar 27, 2012 | 03:34 PM
2QUIK6's Avatar
It's a change of one number in the constants table for the injector size.
Old Mar 27, 2012 | 04:53 PM
Thumbs up Re: Tuning Changes For Just A Fuel Injector Size Upgrade?
2QUIK6, that's what I was hoping it was ...... a simple change!
If I'm using TunerCat to make this change, do you know what table this value is found in, and ..... what should this value be for Ford SVO (i.e. "green top") 42 lb/hr injectors?
Old Mar 28, 2012 | 07:55 PM
ACE1252's Avatar
Constants-->Fuel Parameters-->Injector Flow Rate.
For Injector sizing read this....
Originally Posted by Injuneer
To get the minimum recommended size for an NA engine, multiply the flywheel HP by 0.07
That assumes an 0.476 BSFC and 85% DC.
Example: 500 HP x 0.07 = 35#/HR
For converting Ford injectors ratings to GM LT1 pressures, do the following.
Formula referenced from Greg's book, Designing and Tuning High Performance Fuel Injection Systems.
Qf = Qn x Sqrt(P2/P1)
Qf = final flow rate(GM injector flow)
Qn = reference flow rate (Ford Injector flow)
P2 = final pressure(GM pressure in bar)
P1 = reference pressure(Ford pressure in bar)
Qf = 42lb/hr x Sqrt(3 bar/2.7 bar)
Qf = 42lb/hr x Sqrt(1.11111)
Qf = 42lb/hr x (1.054)
Qf = 44.268 lb/hr
That should be the number to plug in to the Injector Flow Rate for FMS 42lb injectors.
There are also Injector offsets and short pulse adders to consider.
Read this....
https://www.camaroz28.com/forums/com...ts-lt1-770192/
Old Mar 29, 2012 | 10:48 AM
Qf = 44.268 lb/hr
Read this....
ACE1252, WOW! I really hit the "mother lode" with your post.
This is precisely the information I was looking for in my original post, and ......... I can't Thank You! enough for it.
Thanks also to all who replied!
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
Jul 4, 2005 05:00 PM
