tuneup
Old May 27, 2008 | 07:55 PM
remy2435's Avatar
tuneup
im looking at doing a tuneup on my 97 z. and was wondering what all i should replace, where to get them at, and possible prices to expect. as always any info is apprectiated. thanks
Old May 27, 2008 | 08:12 PM
mad95z's Avatar
I Would look at what the vehicle owners manual recommends at that mileage interval.
I'd be suprized If you have never replaced spark plugs/Wires, if you haven't its time to replace them. Get parts from summit racing/jegs
Old May 27, 2008 | 08:30 PM
6SpdLT1Z's Avatar
not to start ****, but i doubt your making 325 rwhp with your mods in a automatic LT1.
as far as maintance goes, i'd suggest cleaning the air filter, changing the fuel filter, plugs, wires, and go from there. if you still have low fuel pressure your fuel pump could be on its way out. If you still have low spark your opti could be on the way out. etc...
Old May 27, 2008 | 10:23 PM
remy2435's Avatar
well its helps that my uncle is a gm mechanic and has been for 30 yrs. and the tuneup is something i can do. you will be surprised what having an uncle who knows motors like no other can do for your hp. and it also doesnt say my headers,gears, and its not an automatic anymore, he turned it into a 6speed. i can understand why you thought that, but i havent modified my sig yet.
Old May 27, 2008 | 10:31 PM
remy2435's Avatar
sorry didnt mean to sound mean in my reply, and im goin to the dyno on sat. so i will post results on mon. and thanks for the advice.
Old May 28, 2008 | 06:43 AM
SnakeOiler's Avatar
Originally Posted by remy2435
well its helps that my uncle is a gm mechanic and has been for 30 yrs. ...
based on that, I see no reason for this thread.
Old May 28, 2008 | 06:53 AM
2000GTP's Avatar
Even with a 6 speed and headers, hitting over 315 at the wheels is pretty unusual. As for the tuneup, your uncle should know what needs to be done. Plugs,wires, air filter, fuel filter, PCV valve, fluid changes, and a cleaning of the throttle body are all pretty common tune up items that are addressed.
thork
Oct 23, 2004 10:03 PM
JWINN
Aug 26, 2004 05:45 AM
12Second3rdgen
N2O Tech
Nov 26, 2003 01:07 AM
DROCK187
3rd Gen / L98 Engine Tech
May 26, 2003 10:48 AM
