tunercat- speedometer calibration -- not working.
Old Apr 30, 2004 | 09:54 PM
sabre81's Avatar
im trying to calibtrate my speedo for my 2.73 to 3.73 gear swap. I use the calulator and it comes up with the values i apply, program and when i start my car my speedo doesnt work. The rpms dont work at all and the speedo jumps from 0 to 150.
help?
correct speedo scaler values?
could someone with tunercat plugin
245-50-16, auto, fbody, 3.73 gears stock tranny and tell me the values?
Old Apr 30, 2004 | 10:57 PM
Did you press calculate to see the changes?
This is what I get:
Speedometer scalar__30
Speedometer scalar fraction__0.991
Speedometer scalar scantool__50.479
Time between pulses for stop__29.715
Pulses per driveshaft rev.__40
Did you then press apply?
Old Apr 30, 2004 | 11:39 PM
sabre81's Avatar
yep hit caculate and apply
now i just manually did the calculations with the formulas and a calculator.
i got
Speedometer scalar scantool__36.199
Time between pulses for stop__1.526
and my tach works now but speedo stays at 0 till about 10 mph then shoots up to 150
Old Apr 30, 2004 | 11:50 PM
sabre81's Avatar
when do help-version info my PCM_EE is version BA. i wonder if i have the wrong file.
Old May 1, 2004 | 09:28 AM
My EE version is AN. Did you try the numbers I posted? What numbers did you get from your version? Were they the same as mine?
Old May 1, 2004 | 11:01 AM
sabre81's Avatar
yeah they were the same. i have a feeling my PCM_EE file is screwed up. Hopefully the tunercat people send me the new version today.
Aaront810
Aug 29, 2020 09:34 PM
LazyLemming
Aug 29, 2015 07:36 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
nosliw
Apr 27, 2015 04:01 PM
