Tubular K member install questions
Old Jun 23, 2003 | 10:55 PM
96z's Avatar
96z
I was thinking about this the other day...if you have the whole motor, tranny, exhuast, etc in the car already could you install a K member...namely a tubular one?
Would there be any sensible way to go about this?
Just wondering....
Old Jun 23, 2003 | 11:07 PM
AndyCLT1's Avatar
That doesn't sound like much fun. I'm installing one now, but the motor is out. You'd have to support the motor while you drop the k-member and front suspension down. I don't know it all, but I think it could be done.
Andy
Old Jun 23, 2003 | 11:35 PM
InjectedSS's Avatar
it can be done but i would imagine it to be a lil bit of a PITA anything is possible though! personally i did mine when i had the motor out of the car! the motor was out for other reasons so i dont think i would pull the motor JUST to install this k-member.. i would definately try it with the motor in the car.. i guess it wouldnt be tooo bad you just need to support the engine and tranny and then just disconnect the rack and pinion and brake lines and then remove the 6 bolts that hold it on to the frame, then the two motor mount bolts and drop that bish outa there! that was the fast version of course
Old Jun 24, 2003 | 12:12 AM
lt1camaroman93's Avatar
I have been toying with the idea of a tubular chromoly k-member for a while now, but i need to know how much weight it will save me before i go spending the time and money.
Old Jun 24, 2003 | 12:16 AM
pgriffith's Avatar
i would suggest supporting the engine up from the top. with a hoist. that way it would give you all the room you need at the bottom to drop the k member.
Old Jun 24, 2003 | 09:32 AM
AndyCLT1's Avatar
LT1Camaroman93
My BMR was 31 lbs. shipping weight. I haven't weighed the old one yet. But, it felt like at least double that weight when I lifted it.
Andy
LeftoverChinese
Jan 14, 2024 03:03 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
Brent94Z
Mar 21, 2002 04:44 PM
