Trying to figure this valve spring thing out. What will/won't fit. Valve float on 847
Old Apr 24, 2006 | 11:59 PM
jsetzer's Avatar
I have the gm847 and some cm 612 springs. My machine shop said that shimmed they would be fine for this cam.
HAHAH, valve float comes on @ 5500 rpms.
I am trying to find the right spring, which looks like it will be expensive.
Whats the max OD that will fit the stock seats? I have read you need them machined for the 1.46 springs, but everyone says the K-800s fit fine. They are a 1.46 OD spring, so how do they fit?
Will any 1.46 OD spring fit?
Is there something close to stock that will work?
Clicky
The Crane single coil spring looks close. Then I could reuse my CMS locks/retainers to save money. My springs now are 1.26 OD and the Crane springs are 1.255, should fit.
I know I can run some springs with locators, by trimming the locator to fit on the stock seat, again I end up buying springs, locators, locks, retainers... so a bit expensive.
Old Apr 25, 2006 | 08:40 AM
WS Sick's Avatar
Re: Trying to figure this valve spring thing out. What will/won't fit. Valve float on 847
If you have the head off have the seat machined for 1.50s and have it sunk .050.
If the head is on buy some K-800s and a proper seat , remove stock seat and seal, add new seat and new seal, Install spring with a +.050 keeper. Shim to 1.90.
I have been using these springs on several cars (mine and freinds) with the 847.
I started with mine installed at 1.83 on my AFRs with the regular keepers (most height I could get) but it was wearing lifters and breaking the 3/8th studs. After I moved the height up to 1.90 with a new set I can rev freely to 7000 (by the factory tach) and keep my studs in place.
Old Apr 25, 2006 | 10:28 AM
jsetzer's Avatar
Hmmm,
I have the 7/16 studs so that will help. What retainers are you using on these?
Looks like either way I am going to be coughing up some change.
Looks like K800s, retainers, locks, seals, seats are going to set me back a good $250.
*Edit Hello Perry, small world.
Old Apr 25, 2006 | 11:45 AM
WS Sick's Avatar
Lol yeah it is...lol
I am using the Titanium retainers that came with my AFR heads.
I will be at the track this Friday, were you planning on coming by (COFBA thing).
Old Apr 25, 2006 | 12:45 PM
jsetzer's Avatar
Depends on a lot of things, lol. Shortshifting the 847 @ 5k won't be much fun.
Crane told me to use these, CRN-11309-1
its their single spring kit... said it would be plenty.
Old Apr 25, 2006 | 01:10 PM
WS Sick's Avatar
I used the same kit before on my old 93 with the CC305 and 1.6s. They worked good with that cam revving to 6300. But you have just a tad more lift with the 847 (lol) I used them for about 3 years without any trouble.
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
