true duals on an lt1 ? worth it ??
Old Feb 18, 2006 | 04:12 PM
  #46
GREAT_WHITE's Avatar
Re: true duals on an lt1 ? worth it ??
QUOTE=97 RedSS]True dual will gain you some hp Kris...as long as you dont have a problem getting it inspected and dont mind the sound, I'd do it...
Cody[/QUOTE]
AND WHERES MY OBD1 PCM .... LOL
Old Feb 18, 2006 | 04:19 PM
  #47
97 RedSS's Avatar
I had one lined out but someone was wanting to sell their car
Go 3" all the way!
Cody
Old Feb 18, 2006 | 04:36 PM
  #48
Go 3" all the way!
Cody
I HEAR YA.....ITS STILL NO BIG HURRY...ILL JUST HAVE TO COME UP WITH SOME 02 SIMS FOR THE TIME BEING
Old Feb 18, 2006 | 04:48 PM
  #49
Mindgame's Avatar
Lightbulb Re: true duals on an lt1 ? worth it ??
'96 LT4 Corvette
Heads/cam 355 with bolt ons
2.5" dual exhaust, summit x-pipe & borla (3" in/3" out) xr-1 mufflers
428 rwhp/400 lbs-ft SAE corrected
Same car with 3.0" dual exhaust, summit x-pipe & same borla xr-1's
436 rwhp/ 405 lbs-ft SAE corrected on same dyno
more avg. tq & hp from ~3200 rpm up
-Mindgame
Old Feb 19, 2006 | 10:13 AM
  #50
Anymore Feedback??
Old Feb 19, 2006 | 10:21 AM
  #51
truedualws6's Avatar
Originally Posted by GREAT_WHITE
Anymore Feedback??
I can't imagine how you could possibly need any additional feedback.
Old Feb 19, 2006 | 11:49 AM
  #52
med_reject's Avatar
Area is proportional to radius squared but Flow is proportional to radius to the power of 4.
2.5^4 x 2pipes = 78.125
3^4 = 81.
Assuming a perfectly straight pipe and assuming air has zero viscocity and assuming the length of both pipes is exactly the same, the 3" single pipe will outflow the 2.5" dual by a factor of 81/78.125.
Old Feb 19, 2006 | 12:02 PM
  #53
SS MPSTR's Avatar
3^4 = 81.
Why then do duals consistently pick up power over single pipes in applications such as the f-body?
Old Feb 19, 2006 | 12:20 PM
  #54
Brettinator's Avatar
is it worth doing a dual exhaust on an lt1 ??? does anyone have any proven gains or coments on it ???? i was told a single 3" exhaust does better..... comments ?????
kris
The answer is one (1) post in here came close to answering your "proven gains" inquiy. The post where a turbo car made over 1000 rwhp dropped the catback and gained nothing, a turbo setup may not be the best benchmark engine/car setup for the average folks considering duals. The only true comparison/benchmark would be if someone dynoed before & after comparing there old 3" catback followed by a 3" true dual setup which ran all the way to the rear bumper, this way backpressure benchmarking would be compared (keyword 3") to get a true comparison. Changing an identical pipe dia. setup like MindGame did with same mufflers shows the math works but would be nice to see some true dyno before & after results comparing true full duals to a catback with equal pipe diameters.
Old Feb 19, 2006 | 12:27 PM
  #55
89TramsAmGTA's Avatar
After reading all this, this is what I'm going to do with my current rebuild. This will be a 355 with at least 450hp hopefully more according to DynoSim. This needs to be smog legal. Anyways 1 3/4" shorty headers with 3" collector. 3" to the 3" dual cats. Cats will act like a resonator box. Then neck down to 2 1/2" to my Flowmaster 2.50" to 3.50" Y connector. Than the 3 1/2 inch Mufflex system using a Magnaflow 3 1/2 inch muffler.
Old Feb 19, 2006 | 01:03 PM
  #56
3^4 = 81.
Flow in the 2.5" pipes is one half of the flow in the 3". Just read the previous
parts of this thread, and especially the posts by Injuneer. I also suggest you
take a look at some gas law equations if you are really curious.
http://www.lmnoeng.com/DarcyWeisbach.htm
http://www.chem.mtu.edu/~fmorriso/cm...sible_flow.pdf
Old Feb 19, 2006 | 01:15 PM
  #57
This is not 3" single to a 3" dual comparison, it's a 3" single to 2.5" dual
comparison, but logic would indicate that a 3" dual would perform as well
or better than the 2.5" dual in higher rwhp applications (as evidenced in
the Mindgame post). It's also difficult, without many dyno pulls, to verify
+- 5 rwhp. The original comparison was a flowmaster single to flowmaster
dual which netted a 12 rwhp gain.
http://web.camaross.com/forums/showthread.php?t=256932
Old Feb 19, 2006 | 01:27 PM
  #58
ahh indeed you are correct, hence the formulas floating all over. This was a tricky one then, personally I'd love to see some 3" comparison catback vs true full dual comparions but that would take some dyno results and thats next to impossible to find online much less in here. The overaxle duals are getting more popular down here in TX, maybe we'll see some numbers pop up soon.
Old Feb 19, 2006 | 02:34 PM
  #59
So It Pretty Much Comes Down To Is What You Would Prefer....being That Both Come Close To One Another....im Probly Gonns Go Ahead And Do The Dual 3" Since There Is Not A Whole Lot Of Difference... This Has Turned Out To Be A Very Good Post In My Opinion Due To Math Calculation And Feedback.... It Deserves A sticky
Old Feb 19, 2006 | 02:54 PM
  #60
I agree, good formulas & feedback, I may consider duals one day as well, 3" & crossover with Borla tips, but!!! with Kooks stepped race headers & their new 3" Ypipe all being stainless along with the Borla, I'll never need exhaust again. Just so long as the exhaust flow doesn't bottleneck & hold back what the new setup will dish out in 5 more weeks, then I'll be satisfied
