True Dual Quieting Ideas
Old Feb 16, 2004 | 12:34 PM
truedualws6's Avatar
True Dual Quieting Ideas w/Video
I wanted some feedback on a proposed modification to my
true dual exhaust setup to make it quieter. The link is to a
PDF with the proposed modification and the current setup.
Page 1 is what I want to try to quiet things down a bit. Page
2 is the current setup with the Flowmaster race mufflers. Any
comments?
Click Here
.....Added video in next reply.....
Old Feb 16, 2004 | 07:17 PM
Video Clip
See new post "True dual video"
Old Feb 16, 2004 | 07:28 PM
Camaro_Guru16NY's Avatar
I personally think that it sounds fine as you have it right now. I dont think that its too loud at all. Your proposed set up is an idea but you end up bringin the duals together in muffler so i think that it makes it a more complecated single pipe set up, just m.02 though,
-John
Old Feb 16, 2004 | 08:41 PM
-John
The Dynomax has two straight through flow paths so there is
no crossover of the exhaust. The flow paths do share a common
packed chamber. This should accomplish the same thing as a
bullet style muffler, only with more chamber area to absorb the
sound. The thing I need to eliminate with the existing system
is the typical interior Flowmaster resonance and drone. It's like
being in a twin engine airplane where the engines are not quite
at the same rpm.
Old Feb 16, 2004 | 08:52 PM
Vendetta's Avatar
Sounds to me like you need some resonators and longtubes...
Old Feb 16, 2004 | 09:33 PM
Gripenfelter's Avatar
Put two dynomax bullet mufflers inline right before the axle.
Old Feb 17, 2004 | 11:09 PM
Won't a Dynomax ultraflow 17276 accomplish the same
thing as two bullets? It's basically two bullet mufflers
within the same case. Here is a picture of the muffler. The
two paths are straight through.
Firechicken350
Jun 6, 2015 11:25 PM
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
