trouble fitting driver side header in.
Im haveing alot of problems fitting the driveside longtube in it keeps hitting the stearing shaft its disconected but the part sticking out off the colum. I headrd som people put a knick in it how do you do that to make it fitt. There pace setters with emissions.
I've had to unbolt both engine mounts and jack up the back of the engine to lift it up off of the mounts and make sure the oil filter is removed.
Sad part is, once you fight to get it up in there, it will fall out if you're not careful.
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
