tricky cam selection...flow numbers and specs inside
Old Apr 12, 2005 | 11:42 AM
Ws6Envy's Avatar
Backround: Car is a 97 lt1 car, 6spd, ported lt1 castings (175cc intake runner,72cc exhaust,54.4cc chamber, 2.00/1.56 valves) flow numbers...
Int / exh
.100 72 60
.200 141 107
.300 191 138
.400 236 166
.500 262 181
.550 266 184
.600 259 186
need a cam, daily driver, wants it to be quite at idle but screaming like a raped ape at WOT. Nitrous will be used at track. car has lt's, no cats, magnaflow cat back.
any ideas???
Old Apr 12, 2005 | 12:50 PM
kmook's Avatar
Advanced Tech Moderator
Re: tricky cam selection...flow numbers and specs inside
Cam selection should normally be posted in a Engine Tech Forum.
Transferring, thanks.
Old Apr 12, 2005 | 12:56 PM
97bowtie's Avatar
Something 224/236ish, .560/.580ish lift on a 114 LSA would make a good cam for that setup. Are you looking for a custom grind or an off the shelf cam?
Old Apr 12, 2005 | 01:42 PM
Ws6Envy's Avatar
do you think that cam would have a loud idle???because the whole goal is to have a quiet idle
Old Apr 12, 2005 | 03:50 PM
vette40th's Avatar
GM845 (it is the smaller than the 846), a Crane 210 degree intake 220 exhaust(dont have lift but I think it is 510/520)
You might here these cams with 1.6 roller rockers, but with 1.5's they will be nice
A 224/236 is going to be a rumpy idle, not real loud, but a REAL good tune will keep it quite.
I have heard a LPE 219 cam in a 355, smooth as silk but ran low 12's. Better tunes can get the motor to quite down.
Old Apr 12, 2005 | 04:18 PM
97bowtie's Avatar
A 224/236 ish cam on a 114 LSA will have a decent lope to it, but nothing too mean. If the idea is to totally hide the fact that there is a cam in the car, something like a 210/220 on a 114 or 115 lsa would better suit your needs. A stock catback will go a long ways in muffling the fact there is a cam in the car as well. Might look into that (with a cutout) and ditch the magnaflow catback.
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Queens94z28
Nov 20, 2014 06:03 PM
